928 Forum 1978-1995
Sponsored by: 928 Specialists
Cherohala Skyway Run to SITM May 31st
Old 05-25-2013, 02:24 PM
  #31
928 at last
928 at last's Avatar
Default Thanks Jim
Originally Posted by jcorenman
That depends on what you mean by "easy". AO's route is for Google maps, and GMaps doesn't support routes- it only transfers a single destination, no more kmz files, etc.
Mapquest, however, does support exporting routes to Garmin (and some others).
So, step 1: Transfer AO's waypoints to Mapquest. I did that, here's the link: http://mapq.st/13R1JGJ
Open that link, it will show the route. Plug in your GPS, and make sure that "Garmin Communicator" is installed. If you are not sure, click this link: http://software.garmin.com/gcp.html If you've got it, it will tell you, and if not then there will be a link to install it.
Now click on the "Send" button at the top of the map, to the right. Select "Garmin GPS", make sure "route" is selected, and give it a snazzy name like "Banner Elk from Alcoa, AO route", click the green "Send" button. Make sure it says "Success" or "Groovy" or something.
The next step is to spend half a day trying to find the frigging route in your Garmin, then finally give up and get them on the phone to learn that you have a model which won't import routes. ...
Here's the list of models which can receive routes:
http://support.garmin.com/support/se...00000000000%7D
(Note that when it says "series", the "0" as the next-to-last character can be any digit, e.g. nuvi 2597 is part of the "2507 series").
So buy a new Garmin, do the "Send" thing again, and Shazam!! There it is, in "Trip Planner" (or "Routes" on some models). Piece of cake, what could be simpler?
Note that with some models you need to first go to "My Data" or "User Data" and import routes, others automatically import routes.
More info from this link:
https://support.garmin.com/support/s...00000000000%7D
Now some important caveats: First, I transferred AO's waypoints by hand, I think I did it correctly but you never know... So check it yourself.
Also understand that these are just points, and different devices will route you differently between the points. For example, where the route crosses I-26 (between G and H), Google takes you a mile north on 352 to meet 19W, while Mapquest heads up the freeway ten miles and gets off onto TN-395 and goes a whole different direction.
Be not concerned, however, because your Garmin will go yet another way. Our Garmin chose a route close to Google's route, just crossed the freeway on a different road to 19W. Exciting stuff, just be sure to listen for banjos.
And also understand that smart-phone app's are just about useless for this stuff, because they depend on cell data service to load maps. You may be able to pre-cache the data, and Navigon may have stored maps, I don't know. What I do know is that there isn't squat for cell service in most of this area, and particularly not the bits where you want to be careful about navigation.
(Anybody want to buy a year-old Garmin 2460LMT? I'm serious, lifetime maps and traffic, does almost everything you could want. A great deal for $125. Here's a link to the specs: https://buy.garmin.com/en-US/US/on-t...prod87052.html)
And...after checking all the compatibility and the software, the MapQuest app wouldn't recognize the Garmin.
Had to load the waypoints manually into "Basecamp" and screw around from there.
Looks good now though.....got the banjo tuned up too!...
Old 05-25-2013, 09:07 PM
  #32
PCA0891
PCA0891's Avatar
Thumbs up
Love to meet up with you all in Alcoa Thursday evening. First SITM. I've been looking forward to this event for months. Its the closest I will ever be to one and I here it's one of the best. Co-pilot should be OK but need to double check.
Booked at Comfort Suite's Alcoa
Jim, See you Thursday after all.. Very Excited
Old 05-26-2013, 01:59 AM
  #33
jcorenman
jcorenman's Avatar
Robert, that is great to hear! See you in Alcoa!
Old 05-29-2013, 05:17 PM
  #34
Adamant1971
Adamant1971's Avatar
Received 1,061 Likes on 505 Posts
FYI I'm leaving at about 4:30 am tomorrow, crossing the Peace Bridge just before 6 am, breakfast at Denny's in Hamburg, then heading towards Cleveland (10 AM) and on to Cincinnati (2 PM) then down to Alcoa (6 PM).
I can can be contacted by email: adam.henderson@me.com
Or on two way radio on channel 7
Safe driving to all.
Old 05-29-2013, 05:52 PM
  #35
auzivision
auzivision's Avatar
If all goes a planned, I should be right in front of you from Cincinnati on down Alcoa... might be able to caravan.
Old 05-29-2013, 06:19 PM
  #36
Kevin in Atlanta
Kevin in Atlanta's Avatar
Is there a guess of when you will e passing through Sylva? I'd like to join the caravan there?
Old 05-29-2013, 07:45 PM
  #37
Adamant1971
Where is that.
Old 05-29-2013, 08:02 PM
  #38
Kevin in Atlanta
Silva, NC on the map. West of Waynesville, NC
Old 05-29-2013, 10:33 PM
  #39
Adamant1971
I will find out tomorrow, when we figure what time we are leaving Alcoa.
Old 05-30-2013, 12:22 PM
  #40
jcorenman
jcorenman's Avatar
Just north of Louisville, eta Alcoa sometime around 4pm.
First order of business is a bath for the GT!! Bugs, lots of bugs...
(cell is 360 three one seven 6-four-four-2)
Old 05-30-2013, 04:07 PM
  #41
Adamant1971
I'm i75 just south of Cincinnati, refuelling both tanks.
Quick Reply: Cherohala Skyway Run to SITM May 31st
