928 Forum 1978-1995
Sponsored by: 928 Specialists
Mongo's "First Time" - Timing Belt/Water Pump Thread
Old May 31, 2013 | 03:54 PM
  #331
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
It looks like starting the bolts are the issues. Probably just paint gummed up in there, but these things were a PITA to remove. It was almost as if the PO's stupid *** mechanic RTV'ed the screws in there. I'm going to drop a little bit of pipe cutting oil in the holes and drive the screws in after taping the top threads. Hopefully it bites and the oil helps thread the screws in real nice.
Old May 31, 2013 | 05:44 PM
  #332
Mongo's Avatar
Mongo
Fuse 24 Assassin
Those little brackets are in. The champagne color I painted them really makes the cover stand out. Too bad I won't be able to see them once the wires are in.
File Type: jpg
Old May 31, 2013 | 06:11 PM
  #333
Leon Speed's Avatar
Leon Speed
Don't worry, you won't be able to see the cam covers either
Old May 31, 2013 | 08:09 PM
  #334
Mrmerlin's Avatar
Mrmerlin
Team Owner
the cam covers looks great, nice details,
if your careful you could spin the injectors so the wires wont be protruding
Old May 31, 2013 | 08:19 PM
  #335
Mongo's Avatar
Mongo
Fuse 24 Assassin
Thanks! I gave your idea a try but the one sticking out did not want to spin. I don't want to shred the seals, so I will just live with it the way it is.
Old May 31, 2013 | 08:26 PM
  #336
Mongo's Avatar
Mongo
Fuse 24 Assassin
Oh! A while back, I saw that you assisted someone with ignition wire placement. Using the search, I couldn't find which wires get routed behind the the timing covers to their corresponding cylinders. Do you remember which ones they are? Is it wires 5,6, and 7 for the driver side and 1,2, and 3 for the passenger side?
Old May 31, 2013 | 08:31 PM
  #337
Imo000's Avatar
Imo000
Captain Obvious
Super User
Have you taken any reference pictures before and during teardown?
Old May 31, 2013 | 09:01 PM
  #338
Mongo's Avatar
Mongo
Fuse 24 Assassin
I have but not of the ignition wire positions. I think I found the answer to my question googling a picture up of the motor.
1) Plug wires #4 and #8 are positioned around the outside of the timing covers
2) #2 and #3 along with #6 and #7 run acroos the motor and behind the timing covers
3) #1 and #5 go behind the timing cover on a 3 wire separator with the wires respectfully above.
Old May 31, 2013 | 10:20 PM
  #339
Hilton's Avatar
Hilton
Looking good.
My last intake refresh, I snapped a few of those socket-headed bolts trying to remove the brackets (with the covers already off the car).
Luckily the factory provides the bosses on both ends, so I had the covers PC'ed, and then just turned the covers around and drilled/tapped the other bosses
Old Jun 1, 2013 | 01:41 AM
  #340
Mongo's Avatar
Mongo
Fuse 24 Assassin
Just when almost everything is in, you find your lower radiator hose split!
I don't know how I missed that when taking it off, but now I have to wait till next week when a new hose comes in. Bummer..
Old Jun 1, 2013 | 01:54 AM
  #341
OTR18WHEELER's Avatar
OTR18WHEELER
You can call me Otis
just gotta say, been following your progress on this. I think you have done an amazing job on this. I know I will use your 'speriance here for future reference. thanks for your time!
Old Jun 1, 2013 | 02:48 AM
  #342
Mongo's Avatar
Mongo
Fuse 24 Assassin
Does anyone have two 2-ignition wire separators???
Old Jun 1, 2013 | 03:39 AM
  #343
Mongo's Avatar
Mongo
Fuse 24 Assassin
Thanks Wheeler!
Old Jun 1, 2013 | 09:24 AM
  #344
dr bob's Avatar
dr bob
Chronic Tool Dropper
I schedule replacement of ALL the coolant hoses coincident to the TB job. I think I mentioned this somewhere previously. If one hose is split, it's quite likely the others are ready to give up too. That bottom hose is pretty much the coldest one in the system, so the others aren't far behind.
Old Jun 1, 2013 | 01:59 PM
  #345
Mongo's Avatar
Mongo
Fuse 24 Assassin
The bottom one is the only one that hasn't been replaced.
