NEW YORK TECH SESSION APRIL 14!
Checked Amazon and Google and it's listed a number of different ways but only 1 SKU.
I'll be there. I got my demons exorcised last night and have been driving around all day, so far so good. If we get time I'd like to put my car up on a lift and see if I can find where the rear tires are rubbing. I can hear it but I can't find it:/
Chronic Tool Dropper
The factory tool is a real pretty piece, but at over $100 a bit spendy for an individual owner to justify, especially if there are reasonable workarounds. After seeing Rob's in action, no doubt it's easier than my DIY efforts. Fortunately the hubs only need to come off once or maybe twice in the life of a car if done correctly.
So--- I was thinking that something as simple as a threaded pipe cap might work for this duty. It would need to just fit over the OD of he bearing cap. Three or four evenly-spaced holes around the perimiter, drilled and tapped for setscrews similar to the way that factory tool is made. I'm not near my car right now or I'd get the OD of the bearing cap. Maybe somebody has that handy? Then choose the right pipe cap at H-D, a little bit with the drill press and the tap set, buy a few setscrews, and a club tool is born. Bag it up with a bearing packer, and we have a front bearing service kit ready-to-use.
FWIW, I have a small plastic mayo jar that I use with a few inches of paint thinner as a hand-held parts washer. Put in bearings and other small parts that need to be cleaned, lid screwed on securely, shake gently to get the last bits of old grease out. Keeps 'dirty' solvent from other parts cleaning projects out of the bearings completely. Continuing the theme, a half-gallon plastic coffee container does the same for bigger bits.
Good turnout. Had 7 928's (2 are Pete's), 2 911's. Replaced another 928S exhaust with Borla; tightened up x-pipe fittings and changed my front lower balljoints.
Thank you everyone who came and lent a hand. Huge thanks to Pete for opening up 2 bays and letting us play with, I mean use, all of his tools and knowledge!
Thanks for breakfast Thom!!
Location: Wrong Island NY, 04 CTT , 1984 S 5 Speed Slate Blue Metallic
1 Post
Thanks to Pete for hosting and Mike & Patrick for the Borla install.....Cat delete next still to quiet ! Getting on the LIE I totally feel a few more ponys !
it was good to see you again Mike, Pete, Thom. i had thought of taking many pics but i was too busy drooling over your rides without mine there! I took these 3 pics to show for my visit.
Thoms engine bay
![](http://www.emmanuelli.us/PICS/928/928-TECH-102.jpg)
and his cars 11" wide 18 rims, amazing ride!
![](http://www.emmanuelli.us/PICS/928/928-TECH-101.jpg)
Oh and this 86 engine bay left me drooling for mine to look like it some day!
Thoms engine bay
![](http://www.emmanuelli.us/PICS/928/928-TECH-103.jpg)
Another great GTG. Pete you are the best. It was fun working on you car before eveyone came. Worked out well. Brake job and oil change, see you Monday night
good times!
Mike and I are going on the Borla install challenge.
Great to meet the new people.
Any help you guys need let us know.
Let's do Captree or old OBI parking lot one Sun morning.
