Retrofitting wiper arm spoiler
#31
You can call me Otis
Wolfsburg edition VW Rabbit GTI's used those also, just uses air flow to press the wiper to the windshield at high speeds in the rain., then they invented RAINX.
#32
Electron Wrangler
#34
Dean, I am pretty sure your metal one is factory. As OTR18WHEELER said some early VW has factory fitted metal arm spoiler as well. I believe ever since Bosch came up with the spoiler integrated wiper, the arm spoiler was no long used.
#35
Only the back requires modification - fronts fit directly.
reused the side pin from the old rear wiper, opened up the hole one side, filled the middle with a section of polycarbonate wrapped in black vinyl.
This wiper is quite a bit longer than stock - cleans the whole rear windshield vertically.
Alan
Alan
#36
http://www.canadiantire.ca/AST/brows....jsp?locale=en
#38
Electron Wrangler
Alan
#41
Electron Wrangler
If you use the Bosch ICONs they have a mini low profile spoiler all along the blade length - this looks smooth - it can be a lower profile because its longer and there are no open areas to create lift and it exerts downforce all along the blade.
I like the ICONs - both how they perform and how they look - its not stock - but you don't really notice it either - just blends in. I won't be going back.
Alan
Alan
