928 Forum 1978-1995
Sponsored by: 928 Specialists
'86.5 Belly Pan
Old Apr 1, 2013 | 01:34 AM
UncleMaz's Avatar
UncleMaz
Originally Posted by genikz
@MJ - we can build you one too, once I work out the kinks; my treat. I would like to be sure cooling is not an issue, since I covered up the oil pan fins. I think I may cut a long slot in the leading edge to allow airflow over the oil pan, but still protect against large objects.
@MainePorsche - the front "lip" of the pan slides under the radiator. I'm going to use some thick felt to cushion the metal to metal contact. I think the front attachment can be done better, but I'm wary of using any kind of bolt or screw near the rad, since it's aluminum and $1100 (aftermarket). If anything, I'd like the belly pan to be sacrificial and be engineered to fail predictably; hence only two small bolts hold it in place, and it slides out towards the rear of the car. For $40 and two bolts, I can carry a spare assembly to the track.
Thanks Chris. I would just like to check out the details when you are done. I have to do my motor mounts and will be spending a lot of time in that area of the car. My pan is a good 1/2" below the X member. Yikes!
Old Apr 1, 2013 | 05:12 PM
genikz's Avatar
genikz
Painted and mounted:
Old Oct 17, 2020 | 11:42 PM
Strongarm's Avatar
Strongarm
Default Attachment points
Hi, I own an 86.5 and have managed to find a used belly pan-see below. Unfortunately I don't have a workshop with easy access to the car and trying to anticipate what bolts/screws I will need to attach (assuming they're missing). Does anyone have an idea of what I might need? Thanks in advance, Grant
Old Oct 17, 2020 | 11:53 PM
Jerry Feather's Avatar
Jerry Feather
Yeh, I think I might.
Old Oct 18, 2020 | 12:38 AM
Christopher Zach's Avatar
Christopher Zach
Roger. Call him and he will send you the right screws. One at least is different.
I have mine on the car and I think it adds 5hp to the overall performance. Well, it does help the airflow for the AC condenser.
Old Oct 18, 2020 | 12:21 PM
Wisconsin Joe's Avatar
Wisconsin Joe
If your belly pan is gone, the screws are likely gone too.
The speed nuts that the screws go into are probably gone or corroded to uselessness too.
The PET shows the belly pan, but doesn't list any fasteners for it.
A quick search found the sizes for the later ones, but not the early ones.
So the answer for this is pretty much the same as for any other 'where do I find?' sort of question:
Call or e-mail Roger.
Old Oct 18, 2020 | 02:59 PM
hernanca's Avatar
hernanca
From an 86.5 Auto with 100K miles:
Two bigger and 5 smaller ones.
20mm of thread ea. (uncalibrated Rob-O- Meter).
Old Oct 18, 2020 | 03:33 PM
Jerry Feather
Interesting old thread. I found that all 7 of the screws holding mine onto the 85 were the same and all smaller than the ones shown. I plan to provide screws like the smaller of the ones shown with my belly pan and the necessary u-nuts for them. The two outer and upper screws mount into the frame, I think, and I'm not sure iust what to do about the two outer/upper screws. I hate to suggest that anyone put a lorger screw in where the hole is still useful for the smaller ones.
I'm getting closer with my belly pan project and have the forming dies nearly completely worked over to try again. Here is my first squeeze.
Old Oct 18, 2020 | 03:42 PM
hernanca's Avatar
hernanca
Beautiful and amazing work as always Jerry!
If you supply the necessary U nuts for placing smaller screws in the upper-outer locations, that should work fine. My larger screws in those locations appear stock, but I am sure the belly pan has been on and off several times prior to my ownership (motor work), so who knows!
Old Oct 18, 2020 | 04:19 PM
Jerry Feather
Carlos, I think the two outer and upper screw location do no use u-nuts. I think they simply screw into holes in the frame. That's why I am kind of concerned about how to deal with them.
Old Oct 18, 2020 | 05:08 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Correct, the two outer/upper screws are B6.3x19 tapping screws, they just screw directly into a hole in the frame rail. If that hole gets stripped, an M6 nutsert is a nice solution though buying the nutsert / rivnut tool is non-trivial, cost-wise.
Amazon Amazon
Old Oct 18, 2020 | 05:21 PM
hernanca's Avatar
hernanca
(Edit: Cool tool, Rob!)
Jerry,
You are correct, from what I can tell, the upper-outer ones mount to the "frame". I don't have my car on a lift, but I was able to finagle these pictures. Red marks show what I am pretty sure are the respective outer mount points.
(Note that on the right side I am about to lose one of my lower bolt U-nut tabs - it is bent forward! How best to bend that back w/o breaking/weakening? Heat?)
Pan mount - outer left ^^^
Pan mount - outer right ^^^
