Driving Light won't light.
88 928 S4. Left driving light quit lighting. Replaced bulb, still doesn't light. Check fuse panel. Card indicates one fuse for both left and right driving light. Fuse is okay.
Any ideas on how to resolve this?
Thanks.
Thanks.
Team Owner
check the wire harness under that headlight pivot this is where the wires come out and they flex and if the wires are crimped too tightly then they will shear,
You need to remove the block off plate and fender liner and wheel to do this inspection also check the wire connectors behind the bumper possibly one has come loose
