928 Forum 1978-1995
Sponsored by: 928 Specialists
Puffy rear visors. Any fix?
Old 03-02-2013, 12:46 PM
sweet928
sweet928's Avatar
Default Puffy rear visors. Any fix?
Just noticed my rear visors have started to puff. They are vinyl. Can they be repaired or is replacement the only option? Prefer to repair as 34 year old cork floor vinyl is hard to match. I have a good local upholstery guy who did a good job regluing my puffed front seats. I'll give him a call but wanted to check here if anyone has had luck fixing theirs.
Old 03-02-2013, 12:51 PM
Dean_Fuller
Dean_Fuller's Avatar
You will have to replace with something new inside the vinyl. The insides will be crumbled dust mostly. If you can find a set of later S4 visors...they are solid hard foam vacuum fitted with vinyl. That what I did with my son's car.
Old 03-02-2013, 01:19 PM
rgs944
rgs944's Avatar
I guess they put them in there for a reason but I don't know of when I would ever need rear visors?
Old 03-02-2013, 01:38 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Mine are used most frequently to hold up the rear window reflector-shade when the car is parked. In between those duty times I use them to fill those recessed cavity depression areas in the ceiling just forward of the front edge of the hatch glass. They are probably handy for folks travelling in the rear seats, should that ever happen...
Old 03-02-2013, 02:09 PM
Alan
Electron Wrangler
Alan's Avatar
They do shade the rear seat passengers (pretty much has to be kids only) from sun on the head - but they cut down rear visibility quite a bit - I'll bet the % of use overall is in the 0.0001% range.
Wouldn't look too bad with them just removed...
Alan
Old 03-02-2013, 02:43 PM
Randy V
Randy V's Avatar
I've never used them.
They seem like a silly solution to a non-existent problem.
Old 03-02-2013, 03:14 PM
sweet928
sweet928's Avatar
I don't want to repair them for use. I've never used them. I just like everything to be tidy.
Old 03-02-2013, 04:09 PM
rgs944
rgs944's Avatar
I actually put mine in storage. It really does look fine without them.
Old 03-02-2013, 07:49 PM
Jim M.
Jim M.'s Avatar
Mine have been removed for years now. Install a screw in the hole with a recessed washer and paint them the same color as the interior.
Old 03-02-2013, 07:57 PM
jwillman
jwillman's Avatar
Yet another idea I will borrow. Thanks Jim!
Old 03-02-2013, 08:38 PM
linderpat
linderpat's Avatar
Received 2,376 Likes on 1,289 Posts
I say fix them. The interior roof looks like it is missing something if you leave them off. It looks like the car isn't finished. Those indents are too obvious.
Old 03-02-2013, 08:46 PM
77tony
77tony's Avatar
Did a rear seat delete on Just Beachy and had Paul Champagne fill in the rear visor area. Looks great. Will post pics when she comes out of paint. T
Old 03-02-2013, 09:19 PM
linderpat
linderpat's Avatar
Originally Posted by 77tony
...had Paul Champagne fill in the rear visor area. Looks great. Will post pics when she comes out of paint. T
I think that would be the only way to go. It should look like it was designed that way.
Old 03-02-2013, 10:00 PM
rgs944
rgs944's Avatar
Here's the way I see it, if someone gets in your car, looks in the back, and gets past the novelty of wondering if someone could really fit in those seats, then they are eyeballing your car a little to close. lol
Old 03-02-2013, 11:44 PM
GlenL
GlenL's Avatar
Mine help distribute the smell of Lexol. They're leather covered. I can't imagine my car without them.
Quick Reply: Puffy rear visors. Any fix?
