Vinyl wrapped 928
with the spray, the trick is to start with 2 light tack coats, then can go heavier coats. it is thick and looks textured at first, but it stays solvent for a long time and will flow out. allow at least 10 minutes between coats, 1 wheel took about 6 or seven coats to look right. sounds like a long time, but doing all 4 wheels at the same time, you get dizzy going around the car.
Will this work on chrome wheels? I have set that looks pretty bad, so if this works over chrome it would be perfect!
Whats the actual name of the product you bought at lowes?
Plasti Dip is the name of the stuff. It's about $6-7 a can. They may not have many colors in local stores so you might look at the dipyourcar.com site and see the colors they have.
You can call me Otis
the name is "PLASTI DIP" by performix. It will work on any surface just as well, it is very tacky and will coat anything. There are tons of DIY videos on youtube. and the best part is, once it has cured you can peel it off. available at lowes, home depot and online.
Video of it being applied and then removed.
Video Link: http://www.youtube.com/watch?feature=player_embedded&v=vvkq-qyY9aY
Was thinking seriously of using the dipyourcar stuff to do a temporary bra like I did with the duplicolor stuff. The dipyourcar guy says he has thousands of customers using it for spray on temporary bra.
![](http://www.zipbang.com/928gts/gtsbra2.jpg)
I don't see why you couldn't. I bet it would work really well. They have flat and gloss type you could use. I may do it to my car if I like how it performs on the bike.
Originally Posted by MjRocket:10403594
Looks Very good! I still need to get mine applied now that the weathers warming up.
You only need 2 , you will probably have some left over for another use
Another big tip for you guys. Keep the can in hot water in between coats. As you spray the can gets colder...just like a can of compressed air. This cause the paint to thicken up and texturize. Keeping the can in hot water keeps the paint nice and smooth make sure you prep correctly. Here are my pics.
