928 Forum 1978-1995
Sponsored by: 928 Specialists
Driverside Front Cam End Cap - How to remove it?
Old Feb 19, 2013 | 08:40 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Default Driverside Front Cam End Cap - How to remove it?
Short of loosening the front cam shaft cap, what is the easiest way to remove the cam cap?
Any pointers?
-Kevin
Old Feb 19, 2013 | 09:01 PM
ajricker's Avatar
ajricker
I just drilled a small hole in it, screwed a small sheetmetal screw in then yanked it out with some vice-grips.
Old Feb 19, 2013 | 09:54 PM
Kevin in Atlanta
Ok I can do that. In fact I just did that. I drilled a small hole, screwed in a screw. The screw bottomed out against the cam end and forced the cap out. Done!
Kevin in Atlanta
Does anybody replace the from passenger side front cap?
Old Feb 19, 2013 | 10:05 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
the only thing I can add is
dont try to pry on the cam pulley to install or remove the caps ,
this so you dont risk damage to the cam
Old Feb 19, 2013 | 10:34 PM
ajricker's Avatar
ajricker
I didn't change the passenger side cap. it wasn't leaking and I didn't want to pull the cam pulley to get to it.
Old Feb 19, 2013 | 11:15 PM
928Myles's Avatar
928Myles
I changed all the 'hockey puck' type seals on my car. Front ones were not a problem (compared to the rears). A bit tight behind the cam covers but easily doable without removing the cam gears etc.
YMMV
Myles
Old Feb 20, 2013 | 01:52 AM
Lizard928's Avatar
Lizard928
There is a small prying location on the cap...... No drilling is required!
