928 Forum 1978-1995
Sponsored by: 928 Specialists
WANTED S4 CATALYTIC
Old Feb 21, 2013 | 03:57 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
All 32V engines have the same catalytic coverters. It's a direct bolt on. As far as I know, all 16V engines need modifications to the passenger side of a 32V converter pipe to make it fit. It needs to be extended about an 1 inch or around 2.5cm.
Old Feb 21, 2013 | 08:17 AM
Landseer's Avatar
Landseer
Depends on whether or not you utilize 32V headers.
If 16 V, I thought it bolted up but downpipes need to be heated at cat entry and bent a bit for width adjustment. IMO suggests an inch spacer or so.
If 32V tubulars, then you definitely need a couple inches of spacer. Slice off flange leaving 3/8 inch or so of tube on it, weld in a piece of SAE tubing. Again, heat pipes cherry red at cat and bend a bit to adjust width.
A 16V air pipe system will align with the 32V muffler air pipe and they bolt right up.
I thought the early 32V cat discharge pipes were different than S4. Are you sure IMO?
The 86.5 32V cat discharge looks same as S4.
Old Feb 21, 2013 | 06:38 PM
Hilton's Avatar
Hilton
Good to know.. early "Euro" 928S (80-86) all have dual exhaust, so I'm guessing they're the same size pipes aft of the cat. I'll have to measure a local early car to see - a very nice '86 16V came up for sale recently in NZ I was tempted by, but the emissions question held me off and it sold.
(86 is first year here in Oz which would require cats - which is why Australia for the S3 motor with cats in '86. I'd just prefer a 16V '86 instead for a change after owning a string of S4's).
Old Feb 21, 2013 | 08:24 PM
Landseer's Avatar
Landseer
The 16V is just plain enjoyable.
Old Feb 21, 2013 | 10:15 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I'm 100% positive that an S4 cat is the same as an 85 32V. The difference is after the catalytic section. Past the connection.
Old Feb 21, 2013 | 10:25 PM
SeanR's Avatar
SeanR
You are correct.
