WTB: Used Cam Bolt and Thrush washer
I need a used long cam bolt and a thrush washer for my 87 928. PO's mechanic bent the bolt and another bolt's rounded thrush washer is MIA.
Also, if you also have the two plastic clamps that attach the front seat belt that prevents the seat belt tongue from falling to the floor that would be nice, too.
Thanks.
Thanks.
Team Owner
I would not fit a used bolt as you dont have any idea if it has been over torqued,
this is a critical application,
and I would strongly suggest to buy new parts and torque them to spec.
If you happen to install a bolt thats been stretched then it may come loose and damage the keyway and the spider,
resulting in possibly a new cam if you catch it before it causes the belt to come loose or jump teeth.
Yes the new bolt is a bit expensive but a valve job is about 96.354 % more expensive.
YMMV
YMMV
It's not the cost although replacing them all along with the thrush washers is a bit pricey. It's that I am having all powder-coated black anyway.
Team Owner
Roger should be able to get you new parts quickly
From the WSM the bolt varies depending upon year
It's definitely M10
Grade is either G8.8 or G10 - it will say on the head of the bolt
Length also varies - measure the one you have
Then off to the local metric bolt specialist.
They may also have washers to match the existing.
It's definitely M10
I wasn't planning on powder coating the threads. :-)
Archive Gatekeeper
How about the face of the hex washer against the cam gear? IIRC someone had issues with maintaining the torque on their cam bolts after having the gears coated with DFL-1 (see https://rennlist.com/forums/928-foru...r-updated.html) Not that powdercoat and anti-friction coatings are the same, of course, but the PC might alter the friction between the washer and cam gear face.
God knows I've made things that you never see shinier than they were, but I wouldn't mess with non-standard finishes on any of the critical fasteners.
That was an interesting read. Thanks.
Team Owner
dont put any coatings on any of the clamping surfaces of the cam bolt or washer or face of the cam gears where the bolt clamping force is needed to keep the gear in position
I decided not to powder coat the cam cover hardware. I used my wire wheel to clean them up and I will spray them with clear. Here's a couple of pictures of what they will look like.
