Help needed - slipping cam gear - UPDATED
928 Engine Re-Re-Rebuild Specialist
Last night when I went to install the ignition rotors, one of the bolts wouldn't go in because the hole was partially obscured by the cam gear. Although I set the gear timing to 0*, it was now reading on the left-most hole of PorKen's cam timing tool.
I've now discovered after re-setting the timing three times, although the cam bolt is torqued to spec (~65Nm), whenever I rotate the crank 360* to re-check the timing, the cam gear slips from 0* all the way until the cam gear hits the woodruff key.
Bottom line - the cam bolt is not holding the camshaft tight enough to prevent it from slipping against the cam gear.
Has anyone experienced this? What's the best solution? I don't want to overtorque the cam bolt so much that I cause a bigger problem.
Just in case anyone asks, yes, I am using the large washer with the cam bolt (the one that is counterheld when tightening/loosening).
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Here's the bolt that's allowing the cam gear to slip.
I have 2 spare cam gears...maybe try one of those?
Inventor
Seems silly, but... did you remove the 32V'r adjustment spacer?
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Under the Lift
Unless you have the wrong bolt or washer, that is real hard to explain. It may be torqued to 65Nm, but it must have bottomed out. Is there something inside the bolt hole in the cam?
Originally Posted by PorKen
Seems silly, but... did you remove the 32V'r adjustment spacer? ![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Originally Posted by UKKid35
Very strange. Bear in mind that there are also several reports of Part 2 failing causing devastation - and I know you don't want to go back there...
I'm wondering now whether it would make sense to roughen the surfaces of the washer and cam gear so that they stick together better. I'm going to try one of my spare gears first, assuming all other parts appear normal.
The repair is on hold until this is solved.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Originally Posted by Andrew Olson
Is it possible that there's something in the cam that is causing the bolt to bottom out before achieving torque?
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I guess a better idea would be to stick a thin screwdriver into the hole, measure how far it goes in, and then compare it to how far it goes into the camshaft I had to replace.
Originally Posted by WallyP
Or just screw the bolt in without the washer until it bottoms, then compare the washer thickness to the space left...
Thanks for responding, Wally...I was hoping you'd read this thread.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
I've now got a dial caliper that can measure the depth between the current and old camshafts. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
If it's bottoming out, is there a reason why I couldn't just shorten the bolt by a few mm? Would it change the torque requirements?
Captain Obvious
Super User
Super User
Try this:
Take the cam gear off and tread the bolt it as far as it goes, then measure the distance that’s left. If this is close or near the same as the gear thickness then the bolt it bottoming out. This could be from either the hole is not deep enough or the bolt is too long, maybe there is, as Andrew suggested, something in the hole. If the hole is too shallow, it could be manufacturing defect or maybe the bolt is too long, again a manufacturing defect. Then there is the possibility that the gear is too thin, the washer is too thin or the adapter is machined wrong at the factory. In any case it would be as easy as just grinding the bolt down a couple millimetres.
I don’t believe roughing up the washer will solve this problem. The real problem is the lack of clamping force between the head of the bolt and the face of the gear.
