Any interest in a 928 engine stand adapters?
#61
Do the arms have to be round tube? If not, they
could be cut using a CNC plasma cutter out of
plate. Would be heavier but lots of shops could
make them.
make them.
#63
It looks like I need to find another shop to get these done. My normal guys are backed up, and most of the other local people dont want to bend the arms.
I got a high quote from one my backup guys for $400/part but he wanted to just machine everything instead of using tubes.
#64
Basic Site Sponsor
Basic Site Sponsor
Hans:
Rob Edwards bought a factory Yoke from Andial, when they closed their shop, a couple of weeks ago.
I'd sure like to get a couple. I've not read this entire thread, so I don't know exactly what you plans are. Are you planning on making any of these exactly like the original?
BTW....my waterjet/lazer guy also has a CNC bender.....if you need any help/another bid on the pieces.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#65
Greg,
I have a factory yoke here, and have it drawn in CAD, so it would be easy to have the factory tool reproduced. If you have a fab shop you would reccomend, I would gladly send them a print package for bid.
I ran across a fab shop at the Hot Rod an Restoration Trade Show a couple weeks ago. They do a lot of 'Murican tubular suspension replacement bits, but run a full service fab shop as well, and said they would bid the job. I think they were in South Carolina, his card is on my desk.
I have an R2 engine I want to rebuild, so want to get some of these knocked out soon. I really want to use that new engine stand, I think the geared rotation would be a game changer.
BTW, if Rob didnt get the flywheel lock tool, I have that drawn in CAD as well.
Hans
Hans
#66
Well, sometimes things just hit you.
While going back through the thread, I thought of a way to redesign this part so it all can be cut from flat stock. I will try and get this design implemented today. Taking a page from flat-pack design, I will make the "arms" with tabs that will locate in the bell housing flange and stand mounting flange. It will hold together like a puzzle while being welded.
I can just take the bits to a local welder I use, problem solved.
Hans
Hans
#67
#69
Hans
Hans
#70
I thought about this again on friday, but didnt have a chance to take drawings over to the print shop. Only way I know to test/check these drawings to is to print 1:1 and lay the factory tool and bellhousings on the print. I dont have a large enough printer in-house to do this part, so I have to send it off to the architectual print shop downtown who is capable of printing native CAD drawings.
I have been tied up finishing up another concept, which I will post shortly.
Hans
Hans
#73
I'd like to have at least one...... If someone has a design, the fabricators who built both my 928 racers have a connection to a shop that builds their miata roll bars for a great price with great quality... Might be worth getting a quote to see if its cost effective?
#74
I can get a print package together for bid, or send a model.
I have been trying to get the GTS-4 put together for SITM, so not been keeping up on the side projects.
