A little improvement to brakes...
Developer
Brake Master Cylinder Bellows for Porsche® 928
Application: 1978-95 Porsche® 928 all
The Problem: The Porsche® 928 is fitted with a Master Cylinder cap that is vented. This causes two problems:
It allows the brake fluid to draw moisture from the atmosphere, and
It causes the brake fluid to spray out of the cap on DE days, racing, and just good hard driving, removing the paint on anything it touches.
The Solution: This top gasket for your stock brake fluid cap uses a bellows instead of a vent to seal your master cylinder, yet allow for the expansion and contraction of the fluid in the reservoir as per normal use. This is the way all modern vehicles close their master cylinders now - no air is allowed to contact and corrupt the fluid, and no fluid is allowed to escape wrecking your paint job (brake fluid is an excellent paint remover).
Installs in Less than 1 Minute: Installs into your stock brake master cylinder reservoir cap. Remove the cap, remove the old vent and gasket, install the new bellows, re-install the gasket, and put the cap back on your master cylinder. Done. Instructions are included and ship with the bellows.
Priced at $9.50
Listed here: http://www.928motorsports.com/parts/...er_bellows.php
Ordered one
Nice stuff, Carl.
Kind of odd that Porsche didn't have this originally. I've seen this idea on my old GM cars. I'll bet it's common.
Now I will be able to pressure wash the engine bay with less reluctance.
Administrator - "Tyson"
But I like the red rag held on with a rubber band.......... ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
Nice work Carl.
Nice work Carl.
Well done!
I'll order one soon.
