Anyone got a 928 and a tape measure?
#47
Chronic Tool Dropper
The 11-foot column outside width allows you enough space to open the car doors some for in-and-out access. I put the car back a little on the lift to get more door opening if I need to work inside with the door open, again assuming that the space next to and behind the column doesn't also include other furniture/equipment/stuff.
I have the MaxJax columns modeled in AutoCad DWG 3D if anyone needs them for design/layout purposes. PM your email and they are yours.
#48
The roller jack was the biggest offender on the epoxy, a problem minimized by having the MaxJax lift. I think I;ve used the roller jack a couple times in the tw0-plus years the lift has been here. I'm spoiled, that's for sure. Are you still happy with your RaceDeck floor?
#49
Archive Gatekeeper
Bob, got it on the thread sealer, thanks! Really annoying to have to tie a diaper around the reservoir to keep the ATF off the floor.
Also because I hate ATF, I ended up upgrading the quick disconnects to the lossless type, 3/8 NPT with female threads. They're steep (~$50 per pair) but there is literally no fluid loss, unlike the standard ones that come with the maxjax (they lose maybe a teaspoon? Still annoying and messy)
http://www.discounthydraulichose.com...s_p/ht-set.htm
Dunno how often one might be connecting and disconnecting the hydraulic lines, but they might be worth the consideration.
Did I mention?
Did I mention?
#50
Rob--
The little dribble when disconnecting the supplied connectors is inconvenient. I usually sacrifice a paper towel to the duty, placing it under the connector as I pull the connection apart. I still manage to get some on the floor... Guess it's a good thing I don't have to disconnect often. My HPU has a leak, uhhh it's 'seepage', at the connector hose between the pump itself and the flow divider. One day soon I'll drain it all, fix that and a couple other petty connection annoyances, and be happy again. Need to shop for a few 3/8" street-els so the two pressure lines go straight down instead of out sideways from the divider. Plotting the installation for the Bend house, the lines will go straight up to the ceiling from the HPU, same as the way you are doing yours.
For those playing along at home, Rob installed a section of plastic drain pipe in the ceiling with drop-outs over the two columns. Hoses from the columns go up to pigtails hanging from the ceiling directly above. So no hoses on the floor to trip over. Rob put twist-lock electrical outlets in the ceiling there too along with compressed air pigtails, so there will a power and compressed air station at each column. Good stuff that makes things a lot more convenient.
#51
Archive Gatekeeper
After a month of non-stop moving, unpacking, thrashing, reassembling, surviving the end of school year festivities, (oh and working), I finally got to put a worthy car in the air today.
Life is finally getting back to normal around here:
#52
Archive Gatekeeper
Arnoud asked if I could post the dimensions of my half of the garage and relationship of the maxjax columns to the walls and the distance from sides of the car to the walls.
Holler if you need any other dimensions!
Code:
Dimension Inches cm Garage width 167 424.2 Garage Depth 274 696.0 Ceiling height 111 281.9 front of column to garage door 117.5 298.5 Rear of column to back wall 151 383.5 Side of left column to left wall 5 12.7 side of right column to right wall 27 68.6 front of car to garage door 32 81.3 rear of car to back wall 67 170.2 left side of car to left wall 36 91.4 right side of car to right wall 54 137.2 Inside width between columns 115.75 294.0 Outside width of columns 132 335.3
