928 Forum 1978-1995
Sponsored by: 928 Specialists
TB Forensics/Failure Analysis
Old 01-26-2013, 09:42 PM
  #31
928 at last
928 at last's Avatar
Originally Posted by Rob Edwards
Immediate cause of death: Circulatory failure.
Underlying cause of death: Beltosclerosis.
My port-mortem for the belt itself would likely read along the lines of age-induced Haser’s syndrome, resulting in the above terminal condition.
Old 01-26-2013, 09:52 PM
  #32
928 at last
Default And,
And when the owner gets the invoice, I'm predicting the following symtoms will present:
Intense pain (Localized in the wallet area);
Profuse sweating;
Difficulty in breathing;
Pronounced pallor;
Irregular heartbeat with increased heart rate;
Acute hypertension;
And...wait for it.....
**** leakage.
Old 01-26-2013, 10:09 PM
  #33
Randy V
Randy V's Avatar
Original 18 year old belt.
Stupid should hurt.
Old 01-26-2013, 10:27 PM
  #34
Mike Simard
Mike Simard's Avatar
Original 18 year old belt. One day the car wouldn't start. Owner kept hitting the key, until it wouldn't turn over anymore.
This means the belt's good for 17 years, 364 days!
Old 01-26-2013, 10:55 PM
  #35
Don Carter
Don Carter's Avatar
How many miles on the car?
I helped change an original belt on a 91S4 a year or so ago. The car had 43k miles and the belt looked fine, but maybe looks can deceive on old timing belts. Could have turned out like this.
Old 01-27-2013, 01:11 AM
  #36
Lizard928
Lizard928's Avatar
My first guess was correct.
What do I win
Old 01-27-2013, 05:44 AM
  #37
FredR
FredR's Avatar
Hmm! Assuming 32 pieces of "Bent Silver", everything in the cam drive system up the shoot, wobbly valve guides, pistons OK[carbon dent only?]- any takers for the final bill here?
Start the bidding at $10k for the repair? Whatever it is going to hurt- how the $*&k does a 95 still have the original TB on? Criminal- 5 years hard labour appropriate here?
Old 01-27-2013, 07:00 AM
  #38
Leon Speed
Leon Speed's Avatar
So much for looking through the belt cover holes to see if the belt is there.
Old 01-27-2013, 09:03 AM
  #39
danglerb
danglerb's Avatar
I couldn't figure out what would have made it break, so not surprised to hear it was cut off.
Rob how about measuring or comparing it to a new belt?
I am thinking failure may have been stretch, followed by slipping on the crank. When the motor stops seems like the most likely time for a tooth skip as the motor may actually turn backwards a bit.
I've heard plenty worse about first time Porsche owners. People used to US cars that never needed oil added to them. Whatever this costs, when the owner is done they will have a dandy 95 GTS.
Old 01-27-2013, 09:54 AM
  #40
voskian
voskian's Avatar
91GT I bought last August with 24K miles had all original TB, WP and tensioner. Replaced all parts, and they all looked new. Car had not been driven since 2000, but why take a chance..
Old 01-27-2013, 04:12 PM
  #41
IcemanG17
IcemanG17's Avatar
this is a MINIMUM $10k repair......look at all those bent valves......piston hits too....I'm guessing those should be replaced...... It could EASILY be $20k plus if the owner decides to upgrade along the way....
sad.....
Old 01-27-2013, 11:12 PM
  #42
Charley B
Charley B's Avatar
So would this count as the first Timing Belt failure, due to the belt, that Greg has seen? He commented recently that he had never seen a failure in which the root cause was actually the belt.
Old 01-27-2013, 11:38 PM
  #43
SeanR
SeanR's Avatar
Crap deal and one many a new owner has had to deal with.
Just pulled this off a 2nd owner, 62k mile car that has been in storage since 2002.
Car was pulled out of the storage unit last week.
Old 01-28-2013, 12:37 AM
  #44
RKD in OKC
RKD in OKC's Avatar
Ouch, seeing that makes my pocket book burn. Still too soon.
Old 01-28-2013, 12:38 AM
  #45
danglerb
danglerb's Avatar
Sean, I don't have a clue what you are showing me. What am I supposed to notice?
Quick Reply: TB Forensics/Failure Analysis
