Valve seals????? need your opinion guys
#46
starting at 100 psi "in cylinder" then shutting off the air it drops like a stone to 10, in about 3 seconds.... thats on only 1 cylinder so far.... maybe my craftsman compressor gauge i bought is not sensitive enough, or cheap. ill do the rest and see what the numbers show.
#47
#49
Jake, would it help if you ran gear oil instead? :P
#50
20/50 is not gear oil? he he he
using the other comprssion tester hose with the valve in it and a ballon to find TDC. kinda neat. but sticking the car in grear does not seem to "lock it down" as much as i would have liked. kinda fun hitting the air, and watching/hearing the 1/2 ratchet on the dampener bolt spin and smack things....
#51
Shameful Thread Killer
It would be good if you had a crankshaft locking tool. Take the oil fill cap off and do the test again. If you have leakage past the rings, it should be pretty obvious. Also, block the throttle plate open and take off the air cleaner so you can hear any leaks going that way.
#52
Man of many SIGs
#53
It doesn't have to be at TDC as long as the valves are closed. Try BDC on power stroke, valves are likely closed there and the piston can't go any further down.
#54
He's got to do that for each piston if he's trying a leak down. Otherwise he'd toss that crank in many different directions.
#55
#57
Precisely.
I meant turn it to BDC by hand and THEN apply air. DO NOT turn crank shaft by hand while external air pressure is applied to cylinder. Things could get exciting in a hurry turning past TDC by hand with air compressor connected.
#58
#60
For you kids playing at home, here are the numbers!
from 100psi to 10psi (in seconds)
#1- 6.8
#2-8.6
#3-13.3 (all that oil?)
#4-7.4
#5-8.1
#6-13.0
#7-7.8
#8-5.3
and here are the plugs!
1-4 (left to right
![](http://i575.photobucket.com/albums/ss197/Ducman82/DSC_0297_zps4647d8be.jpg)
5-8 (left to right)
#1- 6.8
#2-8.6
#4-7.4
#5-8.1
#6-13.0
#7-7.8
#8-5.3
1-4 (left to right
5-8 (left to right)
![](http://i575.photobucket.com/albums/ss197/Ducman82/DSC_0298_zps8207c358.jpg)
