This is what you get when you massage a GTS :)
#32
Who knows what an S3 engine would unleash with head work, cams, headers, and ITBs?
#33
In the universe, outside the 928 bubble inside which the laws of physics are suspended, bigger intake valves allow for more flow and make more power -- 5.0 or not. If the cams and ports are matched to the larger valves, why wouldn't the largest possible valves make the most peak power? I guess theoretically one could be rpm limited and slow down the air speed at lower rpms and lose torque for minimal top end gain. If so, it's high time for the community to figure out how to spin these things like Hondas.
#35
The S4 has larger valves than the S3 - but can't be as aggressive with the timing - so my assumption is that the difference is largely port velocity, and hence keeping the S4 valves with greater flowing cams will push velocities higher and combat detonation.
Of course, I'm just still in the parts gathering and idea-tossing phase - and trying to avoid the expensive parts-tossing phase
For shorter-term kicks I have some S3 cams to drop into one of my S4's (with the collar mod. by that guy in California) to go with an X-pipe I'll stick on it.. while I continue to slowly gather bits for another 5L engine.
#36
Tuomo, you say that bigger valves allow more airflow and therefore make more power, or words to that effect. In the 928 and other universes this is not always so. Air velocity makes a big difference in both purging the cylinders and refilling with the new charge. If valves are too big for the application then air velocity can fall, leading to a loss in power. In essence there is a compromise between volume and velocity that needs to be met.
#38
cams are Stage 2, normal flow... now I wish I went with stage 3...
#39
The velocity is important, in my opinion, mainly because higher velocities produce stronger pulses. But I think you can get the velocity up on any port by just running the engine at a higher rpm (and cams and runners matched to that).
#40
I ain't doing anything more about oil control - the previous engine run plenty good with the same drysump. It pools oil in the heads - so what? There is plenty in the oil tank, even at 6000rpm, so I would live with it. The most important thing is that I always have constant oil pressure
#42
Very solid numbers, as a baseline you must be pleased - congratulations.
Peak HP near the redline will be good for racing. Look forward to tuning updates, stick the long runners back on and take the 70 torques
#43
Alex,
I'm not sure about GTS springs, but I know that S4/GT springs see bind just over .400" lift. The cams you have are .437" lift.
I will send you an email we may be able to get you up to stage III
#45
Nice work!. I would be very interested in your dry sump design if you are willing to share.
I will be in London for a few days this summer. Do you accept visitors from this side of the pond? Are you located any where near London?
