928 Forum 1978-1995
Sponsored by: 928 Specialists
Transmission Mount FIX idea ??
Old 01-03-2013 | 06:17 PM
Dean_Fuller's Avatar
Dean_Fuller
Default Transmission Mount FIX idea ??
This is the mount from my 89 I am about to put back on. New mounts are very expensive and are no longer made as well...so soon they will be unavailable at any price.
The problem appears to be the rubber sides become TOO flexable over time and the mount collapes. When that happens, the trans rests on the crossmember or the metal parts of the mount rest together and transfers unwanted vibration into the drive line.
The fix would be to replace the rubber sides with new but that is not possible. Next thing would be to fill the void between the upper metal mount lower metal mount with something that would NOT tranfer vibration, NOT dry out or compress over time and stay in one piece. ( and not split...falling out the sides.) Right now I have an exhaust hanger ( porsche made) that I trimmed down and shoved in. Its about the right size. however over time it will dry out and most likely just fall out.
What other ideas are out there to fix this???
What else could be used to "shove in there" and NOT dry out or split?
Thoughts???
Easier to try and fix now, out of the car than later, on my back.
Old 01-03-2013 | 06:23 PM
SeanR's Avatar
SeanR
I"m so going to use your idea on my car as a quick and cheap fix.
Old 01-03-2013 | 06:24 PM
Dean_Fuller
Here is another showing the metal to metal mount surfaces.
Old 01-03-2013 | 06:27 PM
xschop's Avatar
xschop
I modded a set using liquid poly window weld because it was easier than building a set from scratch. I'll be doing it again soon and will take pics.
Old 01-03-2013 | 06:30 PM
Bertrand Daoust's Avatar
Bertrand Daoust
If you need some height measurement - new vs old (60k miles)
Old 01-03-2013 | 06:38 PM
Dean_Fuller
Wow...in just 60K miles those have already collased that far??? And measuerd with out load.
I would be VERY interested in a measurement with new mounts UNDER LOAD. That way I could tell if I was too high or low on my "fix". Whatever is used as a spacer will compress...just how much will very with the material slected.
Old 01-03-2013 | 06:45 PM
Bertrand Daoust
Here's something - crossmember/trans. - with the new ones installed.
Old 01-03-2013 | 07:07 PM
Eplebnista's Avatar
Eplebnista
On temporary vacation
Does anybody have any idea what the durometer of the rubber is in a new mount?
Something like this two part urethane mix might work:
http://www.energysuspensionparts.com...sp?prod=DIYMMI
Old 01-03-2013 | 07:09 PM
NoVector's Avatar
NoVector
Tony posted this idea a while back. He suggested cutting up an old mount and using the rubber to cram into the void of a new one. In that thread, some thought it might impede flex and compression over big bumps, hard corners, etc.
Old 01-03-2013 | 07:18 PM
Mark Anderson's Avatar
Mark Anderson
The Parts Whisperer
We have sent some off to the people that rebuild our A arms to see if maybe they can rebuild these was well. I'd like to think it isn't much different than they way they vulcanize new rubber on the lower arms.
Old 01-03-2013 | 07:19 PM
xschop's Avatar
xschop
You'll want to use 60A polyurethane as it is as close to the shore of the factory rubber but still a little firmer. I simply drilled two 1/4" holes in the top metal bridge to keep the urethane locked into place when it dried and set it to the 117mm dimension that Rob Edwards posted.
Old 01-03-2013 | 07:40 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
This is not a fix but a band aid. The original mount act as a suspension system and that's why there is no rubber at the top. By wedging a pice in there, the height will increase but it will be a much harsher/firmer setup than a new mount will produce. I've seen pictures of this exact fix, before this thread.
Old 01-03-2013 | 07:43 PM
Calgary Ole's Avatar
Calgary Ole
Would Dean's idea be a good way to test for unknown vibration?
I am chasing a slight vibration in the driveline and this might help elimenate a possible cause. Thoughts?
Old 01-03-2013 | 07:51 PM
Dean_Fuller
I agree its a band aid...but ..there will be NO NEW mounts one day if someone else does not produce them.
Old 01-03-2013 | 07:52 PM
Dean_Fuller
How close is the TRANS from the bottom of the crossmember?
Quick Reply: Transmission Mount FIX idea ??
