I want to perform a leak down test on my motor just to see if I have missed anything. Just wondered if anyone had any recommendations for size of compressor I can get away with.
I would think it only needs a small unit [1/2 HP?] with a bottle on it unless you a hole in your piston.
Much appreciate if anyone can suggest such a typical size/reasonable make of unit for guidance albeit I need a 240 volt unit for our power supply system.
I'm guessing it won't matter much just increase the waiting time a bit more if you run out of pressure. A standard model, 1 -2 HP, 8-12 Bar, 50 liter will do fine.
