S4 MAF ID measurement?
Im away from home...and workin on thingie.
Whats the ID of the S4 MAF where air first enters it?
Thanks!
I want a measurement as good as a Rob Edwards one...at least 4 digits out.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
*kidding*
Thanks!
*kidding*
Archive Gatekeeper
3.606
Pictures or it didn't happen.
The Parts Whisperer
Archive Gatekeeper
Mark's picture:
3.602" = 91.49 mm.
This sounds like one of those jobs that one a them 3D printers could do.
3.602" = 91.49 mm.
![](https://webfiles.uci.edu/redwards/public/Anderson%20MAF%20ID%20picture%2012-13-12.jpg)
Too hot for 3D printing material IMHO..Id want at least 300d deforming safe material there.
And..is that the ID below the screen? I dont recall if there was a lip in there.
Archive Gatekeeper
Ok, I went out and bought a MAF, cleaned it up, and diassembled it, just so I could measure some ****. Just for you, Jeff. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
MAF elbow sealing surface OD, 95.57 mm:
![](https://webfiles.uci.edu/redwards/public/85-95%20MAF%20sealing%20surface%20OD%2095-57mm%2012-13-12.jpg)
MAF screen lip ID: 91.49 mm
![](https://webfiles.uci.edu/redwards/public/85-95%20MAF%20screen%20lip%20ID%2012-13-12.jpg)
MAF 'main bore' ID: 86.32 mm
![](https://webfiles.uci.edu/redwards/public/85-95%20MAF%20main%20bore%20ID%2086-32%20mm%2012-13-12.jpg)
MAF screen diamter: 91.56 mm
![](https://webfiles.uci.edu/redwards/public/85-95%20MAF%20screen%20diameter%2091-56mm%2012-13-12.jpg)
MAF screen thickness: 1.23 mm
![](https://webfiles.uci.edu/redwards/public/85-95%20MAF%20screen%201-23%20mm%20thick%2012-13-12.jpg)
And for kicks, overall length: 130 mm
![](https://webfiles.uci.edu/redwards/public/85-95%20MAF%20length%20130%20mm%2012-13-12.jpg)
And OD of the thin rim butting against the MAF elbow: 100 mm
![](https://webfiles.uci.edu/redwards/public/85-95%20MAF%20thin%20flange%20ring%20OD%20100-54%20mm%2012-13-12.jpg)
Archive Gatekeeper
Yes. I am very accurate, late at night after a 13 hour day, with my $12 Chinese digital calipers. Makes you wonder about all those weights and measurements and torque values that I post.
Basic Sponsor
Jeff, I still have the rotary table set up in my mill so I could mill some kind of ring for you. 1.25mm is very close to .050 in, and I have some aluminum in that thickness. Can you describe better just what it is you need? Maybe I can make if for you.
ReDesign by FEATHER
by Jerry Feather
Producer for 928 of:
-Hatch Latch Receiver Liner--All Versions
-Replacement Heavy Duty Spare Tire Cover
-Flush Center Console Conversion
-Cowl Cover, Cowl Seal, & Shell Stickers--All versions
(RHD included)
-Aluminum Gas Cap Ratcheting Pawl
ReDesign by FEATHER
by Jerry Feather
(RHD included)
I have some mosquito netting i may swap it out for to see if there is a drastic change in performance.
