928 Forum 1978-1995
Sponsored by: 928 Specialists
I have successfully grafted a massive Delco Remy 24SI onto my engine.
Old 12-10-2012, 01:54 AM
danglerb
danglerb's Avatar
Originally Posted by Lorenfb
"I'm upgrading to 100w headlights"
That's only about 16 more amps (assuming 2 100W buibs).
And all that effort for 16 more amps? The stock Bosch
should easily handle that.
Option some like from I think Roger is 80/100, but it runs both filaments in the high mode.
Still I see your point, and tend to side with Santa.
Old 12-10-2012, 11:10 AM
LT Texan
LT Texan's Avatar
Originally Posted by Alan
...A remote (cooler) voltage regulator makes more sense... since heat and especially over aggresive heat compensation is the real problem we have...
Alan
That's a great idea. Rectifiers too? Those babies get hot. Didn't cars mostly have remote voltage regulators back in the day?
Old 12-10-2012, 11:36 AM
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by LT Texan
... Didn't cars mostly have remote voltage regulators back in the day?
Yes most did, you can get remote regulators for Bosch alternators - see http://www.davebarton.com/AdjustableVoltage.html
This is also adjustable voltage.
... Rectifiers too? Those babies get hot.
Regulators are often modularly connected for replacement - makes for easier remote adapter options - and the current levels involved - just 3 small wire connections. Remote rectifier diodes would require a high current 3 phase (3 big wires) connection to the alternator and some kind of forced cooling or a very large heatsink... not so practical and usually not so modular.
Just a gentle reminder on variable alternator voltage...
Of course - if you think about it - setting the voltage higher will not help one jot at idle - in fact the higher you set it the sooner it will start to droop...
Its just physics - the alternator suffers from a power generation limitation at idle - so if you ask for a higher voltage you are asking for higher power consumed in everything that is active... and not in ratio to the voltage increase but actually at a square law...
So if this baseline power is raised you will just hit the power limitation sooner at idle - there are some second order effects - but they aren't that significant.
Alan
Quick Reply: I have successfully grafted a massive Delco Remy 24SI onto my engine.
