Which 42lb injectors to get..?
I see no issue running a 42lb injector of modern design. They should ''vapourize'' the fuel pretty well. A 42lb injector is not as large as the ''Green Giant'' name might suggest. In European 4 and 5 cyl engine tuning we use injectors twice this size.
Although I have a custom intake manifold, I am pretty sure that these injectors do not require any modification to fit the stock fuel rails and clips and are direct drop-ins.
I am seeing just over 70% duty cycle on the green giants at 6,700RPM. It has been a few years and a bunch of changes since I dynoed at 475hp (406rwhp) so I am probably closer to ~510hp now. I am currently running an Eaton M112 which is most probably less efficient than a centrifugal compressor that you plan to run.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
In my calculation the 36lb would be maxed out. I do not wanna run a maxed out injector at the top risking a lean mixture......
Are you using a Std. MAF, or a Supermaf with your output?
I have sixty pounders and they work just fine for me. The injectors were sourced by John Kuhn. We talked about it, and flow matching is not a terribly relevant thing with the stock manifold and batch fire system. With this intake manifold, you're never going to be that close to balanced.
I am currently running the Stock Regualtor and the two dampers. Ive been thinking about removing the 2 dampers. Any benefit from this?
I am running a SuperMAF. I was maxing out the standard MAF. I am also running the stock fuel rails with both dampers and stock regulator. I didn't see any reason to remove the dampers, and figured there must be some kind of reason why Porsche put them there. I also have a Bosch 044 fuel pump with Tim Murphy's stainless strainer and the in-tank pump removed.
Dan
Dan
Dan
Dan
I will try to maintain both dampers then. On the other hand, Ive heard many who has removed both dampers without issues.
I'm running without dampers on my car, 52lb RC Engineering fuel injectors and 55 psi fuel pressure (at 0"), 2 Bosch 044 fuel pumps and
15 psi max boost. Ran pretty well this season. Of course it took Bill and I a while to get it tuned and running this well.
Estimated output?
It's a Open Road Racer:
https://rennlist.com/forums/928-foru...lenge-orr.html
It's dynoed 460+ rwph with the best at 531 rwph:
https://rennlist.com/forums/928-foru...-dyno-run.html
George
90 S4 (Murf #6)
94 GTS
George
90 S4 (Murf #6)
94 GTS
George
90 S4 (Murf #6)
94 GTS
George
90 S4 (Murf #6)
94 GTS
