Auto Trans FAQ Facts and Answers
#47
Referral sheet for MB approved transmission oils: http://bevo.mercedes-benz.com/d/d/en/Spec_231_1.pdf
All approved oils which should be used: sheets 236.1, 236.6, 236.7, 236.9, 236.10,236.81 (see here and select from dropdown box http://bevo.mercedes-benz.com/bevolisten/236.1_en.html)
Oils which can be used: sheets 236.8 (artic climate only), 236.12
Thanks Kurt for the info.
#48
While I understand that the Mercedes trans is not a Chevy, the automatic forum at Yellow Bullet has a wealth of info about clutches, clearances, etc. And it seems to carry over a bit.
#49
Yes. I have learned alot. I am doing my 4l80E.
#52
Throttle Cable Adjustment
