I may have an 84 Euro motor for sale soon.
I am going to attempt to bring the car back using the stock motor. It was compression tested, and appears to be a good motor. Everything else on the car is in good shape under the hood... hoses, fitting,s etc. Everything looks well cared for.
Anyway, In the event that I end up needing some supporting parts that are going to cost an arm and a leg, I will pull it out and go over to the dark side. If that happens, there will be a good 4.7 Euro motor for sale.
IMHO, your 80 would be a better SBC candidate, unlss you find this Euro motor to be junk.
Disclaimer: I am biased and a purist....
If you want to do a hybrid, you are better off buying one where most of the work is already done. http://seattle.craigslist.org/est/cto/3437447040.html
You can sell the Euro to help fund the purchase.
FYI, the trans is the posted car is worth over $1000 alone
Throw in those wheels and the coilovers and you are already at the purchase price.
Drop in a motor to your liking.
Team Owner
If you're going to drop in a chevvy motor, please sell the Euro as-is and use your US-model chassis.
The only notable thing about a Euro versus one of the US models is the engine - so it shouldn't affect your plans, as both cars will require re-wiring to accomodate the chev engine. The Euro LH engines are rare enough in the USA already that you'll get a fair bit more money for it than the other car anyway.
You need a valve job, replace any bent ones, new guides, a gasket set, and MAYBE rings and bearings, but except for really high mileage or abused motors those are often fine. The motor is rarely a big area of expense on a 928.
Chances are many if not most of the hoses etc will need replacing.
