Cyber Monday at Hooked on Cars
Cottage Industry Sponsor
One day only: 15% off of the following items:
- Clear front turn signal lenses for 924, 944, and 928
- Clear side marker assemblies for 944 and 928
- HeatShield Window Shades for 944, 968, and 928 (if you need Heat Shields for other cars, please contact me)
- Hood Liners with and without decals for 924, 944, 968, and 928
- AutoArt 1:43 scale 928 models
- Herpa 1:87 scale 928S4 Personal Collection models
Use promotion code 20CYBER12
To pay with PayPal, choose regular Checkout
To pay with Credit Card, choose Google Checkout
Note: Sale begins November 25, 2012 at 9PM Pacific Time (midnight Eastern time), and ends at Midnight Pacific time on Monday, November 26, 2012. Minimum Order $50. Please allow extra time for shipping.
On the front and rear clear light lenses assemblies...
if i order the assemblies....(got my mouse on the checkout button...its itchy!!)
will the 15% be extended to the lighting of the clear lenses also ?
I dont want a colored bulb showing through the clear lens when its not operating.
i assume this is what i will need for the front and back...
Porsche 928 US Rear Side Marker LED Kit Red, including Resistor
Porsche 928 Turn Signal LED Kit Amber, including Flasher Relay, for US models
http://marketplaceadvisor.channeladv...00&i=244152722
http://marketplaceadvisor.channeladv...00&i=237159794
Anyone have feed back on the turn signal function and lamps check with the LEDS like this?
Sorry for the delay in answering. I'm out at a client site and can't currently access the store system.
I will honor the 15% discount for both the smoked side markers and the LED kits for the side markers or turn signals.
Please send me a PM with the following information, and I'll create an invoice for you, which you can pay tonight or tomorrow:
- Your full mailing address, email, phone
- Which items you want to order
- Whether you want to pay with PayPal (easier), or Credit Card (You will then get a separate Google Checkout Invoice).
Thanks!
PS: As to the hood liner and pressure washer - I have never tested this, so I would be careful not to put the direct pressure on the liner.
Thanks!
Hi Nicole!
Payment sent for 2 front CLEAR side marker assemblies
________
Jimmy
89S4 Black black
________
Jimmy
89S4 Black black
I don't want a colored bulb showing through the clear lens when its not operating.
The Lamp control will most likely not like the LED's and give the bulb warning, this can be easily jumper-ed out at the Lamp control "Female" plug, that's what I did and most others from what I have read.
If you chose to install the "load" resistors, the the Lamp control should not notice the change, but the resistors get hot so be careful where you install them.
Hope this helps,
Dave
Thanks for the input, Dave!
The rear marker lights don't flash; the front turn signals flash properly with the flasher relay included in the turn signal LED kit. No resistors required for front turn signal LEDs.
Only if you use LEDs in both the front AND the rear turn signals, you will have to add resistors somewhere, as even the LED flasher relay doesn't like LEDs on all ends.
In most cases, only the front turn signal bulbs are replaced with LEDs, and then it works perfectly.
Tell us more - is there another thread about this that I missed?
Yes, we do not recommend to install those on painted body panels or plastic parts.
Some of my customers run the rear side marker LEDs without resistors and don't get a bulb warning; I have not figured out a pattern based on model year or other factors, though. It's definitely worth a try before installing the resistors.
This is correct, I thought he was also doing Tail too, however the tail and the side markers are tied together(powered) from the Lamp controller.
I'm running LED's for both Front and Tail Turn and they flashed the same with and w/o the LED Flasher(depends on which type of flasher was installed stock) and load resistor (I'm not using a load resistor, but did need to jump out the Lamp Controller).
Yes, because the Front lights and not powered through the Lamp controller, the Stop, Tail and Rear side markers are (not license plate) on 86.5 and older until it became an option on the early models.
Yes on the newer (not sure when) the LED's on the Stop will have an effect on the cruse control, and the Load resistor will be required to fool the Lamp controller that the correct wattage lamp is installed.
Yes and the metal will provide a "heat sync"
Please do a search on the LED threads, some are long but contain a log of great info.
Dave
