Could somebody please measure resistance of up-to '88/'89 dash illumination rheostat?
As I'm wrapping things up on the PWM instrumentation lighting dimmer project, there's still one thing I'd really like to verify: the resistance on the dimmer potentiometer/rheostat that was used up until '88 or '89 models (and I'd like to know at what year the change-over occurred, too, as I see conflicting information in the various on-line sources I've looked at).
This is the one I'd like to have measured (photo from 928 International), the 928.613.121.01:
![](http://www.mailordercentral.com/928intl/images/92861312101.JPG)
I'm looking for the maximum resistance, i.e., when the wiper is at the farthest end of the resistance wire coil. I guess I could just buy one, but I haven't found any used ones available and the new ones are rather expensive (> $60) and I'd have no further use for it aside from measuring its resistance.
I'm hoping it's close to the value I measured on my '90's 928.613.031.00: approximately 6 Ω. If it's significantly different (and I'd hope it's higher resistance if it is different), then I'll need to supply slightly different configurations of the PWM dimmer module.
that's a good question. I do not like driving at night but am occasionally forced to. No telling how many bulbs are out on my panel but cranking the stat full up gives me a faint view of the instruments. My first
idea is to just jumper the thing and see what i have.
OK, I wound up buying one of these 928.613.121.01 rheostats from 928 Int'l (not cheap!). Just got the shipment today.
It is about the same resistance as the newer-style 928.613.031.00; about 6 Ω. That's good news.
I'll probably sell this one off at a loss when I'm done with the PWM instrumentation lighting dimmer project.
An interesting observation about these rheostats: they're pretty damn unreliable. Right out of the sealed bag, I found it difficult to get a good resistance measurement; when rolling the wheel, I'd often find it going "high resistance" (i.e. more resistance than the 0 Ω to 6 Ω that it should have been). Using it with a bench testing setup (with my dimmer module and a bunch of LEDs), it caused a lot of nasty flickering as it was adjusted.
It seemed unlikely to me that the problem was where the wiper contacts the resistance coil wire, but rather that there was a bad connection at the wiper's center pivot point; there's a tension washer between the rivited-on arm holding the thumb wheel and the copper wiper arm that provides the electrical connection. The current path is through that arm, the tension washer, and then the wiper arm.
I applied some DeoxIT at that point (soaked the tension washer), and the rheostat performed quite nicely after that.
Moral of the story: when trying to resuscitate a poorly-performing rheostat, make sure to pay attention to all the moving contact points, not just the most visible wiper-to-resistance-coil contact area.
