928 Forum 1978-1995
Sponsored by: 928 Specialists
Lizard shifter and front shift guide
Old Dec 1, 2012 | 06:19 PM
hb253's Avatar
hb253
Originally Posted by Tony320
saws-all success! Shifter install complete and works great. Except, I can't get into first or reverse unless I loosen the shift-lever bolt. Time to get under the car and replace those bushings.
Before changing bushings, inspect them from underneath and check rotational play. If there's just a tiny bit, you don't need to replace.
I say this because I recently installed the Lizard short shifter on my 84 and it works fine after adjusting the coupler. My existing bushings have a tiny bit of fore-aft play and pretty much zero rotational play.
Hugo
1984 928S
1979 911SC Targa
