what does this mean?
I was driving spiritedly taking a sweeping 90 degree curve (over a half a mile) with comfort and ease when a message blaired out at me "differential control off".
I noticed no drivability issues, nor over the rest of the 100mile trip either....
I have a 93 gts...
any one know what that means besides the obvious...???
thanks in advance
the diff is a 2.2 on the gts tranny that has extra discs to help handle the added hp ...transmission fluid on the full mark when I arrived home....any thoughts??
I have a 93 gts...
thanks in advance
I didn't know the GTS's could speak. Impressive.
Ha Ha !! I try to do what ever she tells me !!
Thanks Lizard... I will get it checked out!! It was just serviced by Greg last yr....so should be something simple I hope...
andy
andy
Hey Lizard , I see in your signature that you have a crankcase pump installed , does this mean to depressurize the crankcase and allow the oil not pack in the heads as easy ..??
Archive Gatekeeper
I am coming to hate the 'DCO' (Diff Control Off) message, mine is intermittently intermittent. Today it was set off by hitting an expansion seam on an overpass, and I lost my speedometer for a while, then it was bouncing around, then went back to zero. Restarting the car cleared the fault. Loose wire somewhere....
Sometimes a smoky burnout helps get it back, I suggest you give it a try
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
It could really be anything (pump, sensors,etc, etc) but it's telling you it can't 'do its thing', so it stops trying, instead of going through an infinite number of attempts ... until you go through an ignition start again.
I use the vacuum pump to pull a vacuum in the crankcase, and then yes use that said vacuum to pull oil out of the heads. It does help the rings to seal as well for adding power.
Former Sponsor
I have a 93 gts...
thanks in advance
I have a 93 gts...
thanks in advance
Restarting the car should reset the system.
Go out and try it again. If you keep getting that message, the first thing to try is to clean all the contacts and connectors with some sort of a high quality contact cleaner/oil.
There's a post somewhere about cleaning the lateral acceleration sensor. They are pricey and cleaning would be my first choice. Rob Edwards was in the thread so you could search with him and lateral as your search terms.
I've been getting the Diff message for awhile now - assumed it meant I needed to flush the PSD, which is way overdue.
Archive Gatekeeper
https://rennlist.com/forums/928-foru...t-working.html
Post #41. Sean's instructions are below that post.
Would certainly, of course, service the PSD as well.
You can click on the post number located at the upper right of the post to get a direct link to the specific post:
https://rennlist.com/forums/7967533-post41.html
Got it, thanks.
Got it, thanks.
People might be interested to know I have developed a modern replacement for the LAS, which will sell at a much lower price than the Bosch device.... it is being put into production now.
