Time for new wipers, whats best?
This turned up in a search for Micro Edge refills.
43719
Bosch
Wiper Blade Refill/Insert; Rear; MicroEdgeIII; Set of 2; 19 Inch Length
For models equipped with Bosch MicroEdgeIII blades, center bracket will be marked ME3 near center pivot and both ends of blade are covered. This part has been discontinued by the manufacturer, we are limited to stock on hand. This part is currently on BACKORDER.
43719
Bosch
Rennlist Site Sponsor
Advance Auto (and probably other parts stores) have Anco cut-to-fit refills in the narrow size. Work well, and cheap enough to change once a year or as required. Freshness of rubber is a big deal when you are talking about the southern summer sun.
Advance Auto has the Rainx 1/2 off on the second wiper - that was a determining factor. I am cheap. :-)
Electron Wrangler
I have been using the Bosch IKONs for a while on the front and back (built a conversion mechanism for the back
I actually still have my original GTS airblade arms - I probably should just unload them - they haven't been on the car for about 6 years.
Alan
Alan
I am also interested in New blades. But I'm more interested in a blade that will fit tight in the wiper arm. I'm not interested in original and would like to replace the wiper arms with something like the newer Mercedes have.
However I am assuming these would not work with the 928's High Intensity wash system, since the PIAA wiper blades apply a silicone rainx style coating and the high intensity wash fluid is labelled as silicone remover?!
Electron Wrangler
Would actually make more sense to put the rainx in the intensive washer bottle...
Agree with Wally - even the original owners probably never topped it up with stock fluid.. Think of it as a backup tank more than anything else...
Alan
Alan
However, for all of you who are not affected by this potential issue, I would definitely recommend the PIAA wipers - they really are very good, it's like applying a fresh layer of RainX with every wipe.
Electron Wrangler
What is the main benefit - I never really understood Porsche's intent/expectation here? does it deliver? I assume so because you have refilled it...
Alan
