Front Bilsteins. Later Spring length?
I don't know if it's free length of the spring or spring strength or what year they changed, but you need S4 springs.
James
I wasn't being sarcastic. I think the ride height looks about right. Have you measured it, or do you just want it lower?
When I put Bisteins on my '78, the front end was about 2 inches higher than that!
FWIW, my 84 Euro has M474 (Bilsteins), and the front shocks are the green non-adjustable variety (the rears are gold, adjustable). It's an early 84, and as far as I can tell they are original as from factory. My springs have green and white paint markings. The front of my car seems to be right about where it should be – a bit low if anything.
I'll bet your 84 originally had the non-adjustable Bilsteins, and the springs to go with them.
what would the impact or effect be if the adjustment nut was upside down?
thx
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Also if only one of the adjustment nuts is upside down, as it was in the case of my car, it doesn't handle well for obvious reasons.
