928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel gage/warning light question
Old 11-24-2012, 10:57 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Howndo you figure there is that much fuel in there? Measured it?
Old 11-24-2012, 01:16 PM
Tony
Tony's Avatar
run it until it quits, then add a known amount is one way
Recently happend to me. My light failed and i thought i had more gas than was in the tank. NNNNnnnope. Driving along the fuel pressure dropped to 20psi and she started to stumble..pulled into a near by station luckily. I added 10 gallons and for fun I decided to run that tank dry also to see exactly what mileage i was getting.
12.56 mpg (125.6 miles on 10gallons) mixed hwy and some pretty heavy footed city driving. I thought i was getting around 15 or so mixed...guess not!
Light is on the list of things to do in the pod when i remove it.
Old 11-24-2012, 01:26 PM
SeanR
SeanR's Avatar
When my light, and any other 928's I've dealt with, comes on there is right around 3-4 gallons left in the tank. For my car it triggers when it hits the empty hash and I only get 18.5 gallons or so in the tank.
The gauges are notoriously inaccurate due to needle sag.
Old 11-24-2012, 06:24 PM
jbrob007
jbrob007's Avatar
Very common... My guage will only go up slightly over 3/4 tank. When the reserve light comes on I still have 4-5 gallons left in the tank. I know this because all I can squeeze in is 18 + gallons of gas. Needless to say, its a very conservative reading which is fine by me. I always start looking for a gas station when the reserve light comes on but I'm not too worried either.
Old 11-24-2012, 07:13 PM
thezonster
thezonster's Avatar
So it sounds like my situation is pretty normal.
Old 11-24-2012, 07:34 PM
jbrob007
jbrob007's Avatar
Maybe not NORMAL... but definitely very common. If its an easy fix then go for it. I figure as long as I KNOW approx how much gas is in the tank then why worry about it.
Old 11-24-2012, 07:43 PM
Randy V
Randy V's Avatar
Originally Posted by Barry Chan
if the tank is full and the needle is not all the way to the top...
This condition can also occur with a fuel tank that has collapsed due to a clogged vent line.
Old 11-24-2012, 07:53 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
+1
Old 11-24-2012, 09:11 PM
Barry Chan
Barry Chan's Avatar
Collapsed? Sound serious...
Old 11-25-2012, 03:58 PM
Randy V
Randy V's Avatar
Well, it is.
As the tank is a polymer plastic, a clogged vent line can cause it to collapse under vacuum.
A clogged vent line is also bad for the fuel pump and overall performance.
Old 11-25-2012, 06:10 PM
sharkbate
sharkbate's Avatar
I have just the opposite issue. My low fuel light is on all the time in my 86.5. Any fix to that? Thanks
Old 11-25-2012, 08:27 PM
Barry Chan
Barry Chan's Avatar
Well, it is.
Is there a way to check the vent line and where is it?
Old 06-03-2013, 11:08 PM
autoslave
autoslave's Avatar
Thanks,
This thread was helpful to me.
Quick Reply: Fuel gage/warning light question
