Cheap smoke machine for vac leaks
I just received one of these units, I'm looking forward to trying it. I like that it uses DC power.
For the 32v folks, I've read that the smoke can damage MAFs.
@buccicone @Kevin in Atlanta
Where is the best place to attach the smoke output in the 32V engine?
MAF?
thanks-Hoi
MAF?
thanks-Hoi
Unless the later cars have a hot-wire MAF, instead of the barn door style that I've seen in the early L-Jet controlled ones, it shoudn't be a problem.
The reason to clean a hot-wire MAF is that the oil used for the fog can condense on the heated element and cause loss of accuracy due to contamination.
I should have been clearer in my query above.
I wonder why is the MAF the best place for the smoke output? I would think you'd want that as far from the MAF to limit the exposure to the smoke.
It was the easiest place to push the smoke with the adapter I made ^^^. I guess I could have used a solid cap to close off the MAF. Either would work. Ran the '86 over a hundred miles this past weekend. Ran great. Idles perfectly. Post #19 is correct. There was a lot of oily residue after the test. I'm sure by now it is out of the system by now.
I only had two leaks - the one mentioned above one from the MAF cap after not tightening the hose clamp sufficiently. The smoke machine instructions say to limit the smoke time to about 8 seconds each time. That was plenty of time to see them.
I know the unit costs more than DYI'ers would like to spend, but for me it's worth it. A couple of years back a local 928 mechanic struggled for days with a no start after a top end refresh. Turned out to be a loose hose under he manifold. A smoke machine would have figured that out quickly.
