Torque tube clamp alternative
If this has been posted, I have missed it. I have looked at the torque tube clamps for automatic transmission equipped cars and the reasons for needing a better clamp. What comes to mind is that if the tube is pulling away from the flex plate and you stop that with a better clamp, you will still have thrust force pulling the crankshaft towards the back of the engine every time you stomp on the gas as opposed to having the flex plate deflected forward so that you have thrust force towards the front of the engine. Either way should cause excessive wear on the thrust bearing surface wouldn't it? Why do you need a clamp? The tube is clamped at the transmission end. Why couldn't you use something heavy duty with splines similar to Constantine's apparatus but allows the splines to slide inside of it like a clutch disc does? That way the torque tube would never put any thrust load on the engine. Any feedback on this is appreciated. Maybe someone has tried this before and I missed it.
IIRC this was one of the options Constantine looked at but couldn't get to work satisfactorily. I think the concern was wearing of the torque tube splines.
Others will no doubt correct me if I am wrong.
Myles
Myles
So do you get thrust wear on the other side of the thrust bearing if you have it clamped and you drive it hard? I don't see why you wouldn't. Maybe Constantine is reading this and has some input.
Thanks for the replies so far.
I would assume that the wear from driving at higher speeds on the highway should be equal or less than the wear from bouncing across rocks and ditches. I am no expert on this, but I find it hard to imagine that the stress put on a street car drive shaft would be significantly worse than those on a PTO implement shaft. They get slammed in and out and around and about on a very consistent basis.
You are aware that the driveshaft on the 928 is engine speed.
You cant turn these things at 6500rpm...balance issues become the problem.
And as noted, the movement is barely noticeable..it takes a YEAR of abuse to get 2-3mm of total movement. Its another on the trucks, to have inches of movement.
