928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken the bonnet release handle
Old Oct 7, 2012 | 08:46 AM
vsalvato's Avatar
vsalvato
Default Broken the bonnet release handle
Poor me! Whist trying to open the hood I have broken the bonnet release of my S4/MY88; it looks like I have actually broken just the plastic housing and not the mechanism, nor the cable. Can anyone tell me if and where I can find detailed instructions how to dismantle the whole mechanism and replace the plastic housing part, which I understand is quite a cheap spare part, to buy? I did a search iin the forum but could not find anything specific. IS it possible to open the bonnet otherwise if the release mechanism is broken?
Old Oct 7, 2012 | 11:25 AM
9two8's Avatar
9two8
This may help you out ?
http://www.nichols.nu/tip282.htm
Ken
80 928 S
5 Speed
UK
Old Oct 7, 2012 | 05:07 PM
James Bailey's Avatar
James Bailey
You can also just pull way back on the now loose handle and the latch will usually open
Old Oct 7, 2012 | 11:07 PM
linderpat's Avatar
linderpat
It is an easy fix. Also, what Jim said is ususally the case; but if that doesn't work, the hood can be popped from underneath - just reach up with a screwdriver from below and press on the release mechanism and it'll open right up. You should be able to see it with a flashlight from underneath.
As to the housing that broke, take it apart and it will be obvious how it goes together. Just 3 screws hold it on. The other peice snaps onto the fixed plate attached to the inside of the car behind the carpet. The parts are very inexpensive. It is a common fail point.
Old Oct 8, 2012 | 02:50 AM
jpitman2's Avatar
jpitman2
I broke mine, and subsequently softened the spring up at the latch to prevent recurrence, after i rebuilt it. I have seen a complete interior mechanism on ebay, out of germany.
jp 83 Euro S AT 54k
Old Oct 8, 2012 | 03:06 PM
vsalvato's Avatar
vsalvato
Being repaired by a specialized body-repair garage; apparently it was the plastic housing broken; the cover piece is OK and so the handle itself and the cable. I cannot believe that such an exclusive and expensive car had such cheap and fragile parts to perform critical functions obviously subject to frequent use and abuse.
Old Oct 8, 2012 | 03:19 PM
9two8's Avatar
9two8
......., whilst I agree these components are,nt the strongest, they are perfectly adequate.., if maintained regularly, mine are the originals 32 years old.
Ken
80 928 S
5 Speed
UK
