Brakes are dragging..........
She's Rolling Now !
Replaced M/C and rubber lines,flushed the system and it appears that she fixed. Did a test drive and everything worked as it should. Used a bleeder, started at the front worked to the back and got a good pedal.Thanks for all the suggestions.....awesome forum!
Team Owner
I would guess that you didnt swap out the bias valve.. bummer its only halfway fixed
