These transmissions don't "normally" start in 1st gear. Most people that "start" them in 1st gear are manually shifting them. Does this slip occur then, or does it only happen with an "automatic" shift into 2nd gear? If that is the case, how are you getting it to "start" in 1st?
Well, that is a good point. It slipped on normal opp when I started out real light in Drive. I then played with it manually. It may be 2-3 on normal setting of Drive, and 1 to 2 when I am playing in manual mode.
Do you have time on the 18th to take a quick look?
