928 Forum 1978-1995
Sponsored by: 928 Specialists
ABS malfunction- brakes stay locked up. HELP!
Old 09-30-2012, 03:45 PM
davek9
davek9's Avatar
Update!
Brian just called me and removing the Vacuum released the brakes and the car rolled freely.
He then took it for a ride and shortly after some corners they locked up again, I suggested that the fluid now is in need of a change as noted here, and once it cools he can drive it home.
Old 09-30-2012, 04:12 PM
JHowell37
JHowell37's Avatar
When the big check valve is pulled out of the booster, stick something somewhat soft into the hole in the booster and try to get it down to the bottom. A drinking straw should work well. When you pull it out, see if the end is covered in brake fluid. If so, replace the master cylinder.
The symptoms you described plagued me on and off for a few years. Brake fluid was leaking out of the back of the master cylinder and into the booster. In my case the lock up was gradual. But seriously, have them check the booster to see if brake fluid is getting into it.
Old 10-04-2012, 11:17 AM
camboinc
camboinc's Avatar
Update. On Sunday, I unplugged vacuum to the brake booster and the car moved freely. That prompted a sprited drive. Oops. Boiled the brake fluid and the brakes locked up good. Had to let car sit for 5 hours about two miles from home. Upon my return, the car was able to make it home but front right and both rear brakes were still locked up. what a smoking, smelly mess. By waiting until today, the brakes have loosened their iron grip on my shark's desire to move. Now I guess I bleed the brakes and replace the brake booster?
Old 10-04-2012, 05:12 PM
123quattro
123quattro's Avatar
If you disconnected vacuum to the booster and still have locked brakes just replacing the booster will not sort this issue. I would also put a new master cylinder on it for sure. If nothing else it's good preventative maintenance.
Old 10-04-2012, 10:13 PM
fraggle
fraggle's Avatar
hopefully you didn't roast the seals in the calipers... They are NLA, only choice is $200 a pop for the fronts to get new pistons & seals as a kit.
Old 10-05-2012, 01:04 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,319 Likes on 1,293 Posts
sounds like its time to invest in a whole new brake system,
then it ought to last another 25 years with proper bleeding,
right now it sounds like your trying to use band aids.
this isnt a good idea for the brakes
Old 12-02-2012, 07:15 PM
BC
BC's Avatar
Any update on this?
Old 12-03-2012, 11:27 AM
davek9
davek9's Avatar
The car went to a local p-car shop, we know. The fluid was drained, mc and booster changed out.
While attempting to fix HVAC fan issue, the new radiator started leaking lower left side(?).
Then the brakes started to drag again, the shop is thinking its the balance check valve as they seen a similar symptom.
All work has been stopped, until the dust and owners frustration settles.
I volunteered to look at the HVAC, just like an abusive beoch, I want more
Quick Reply: ABS malfunction- brakes stay locked up. HELP!
