928 Forum 1978-1995
Sponsored by: 928 Specialists
What does a failing water pump bearing look like?
Old 10-01-2012, 03:42 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,436 Likes on 1,366 Posts
there are 2 knock sensors,
and also swap out the crank position sensor if you lift remove the intake
Old 10-01-2012, 03:43 PM
Erling G-P
Erling G-P's Avatar
Regarding thermostat:
I had noticed slightly higher water temp for around a year. (3-4ºC).
Suspecting thermostat, I got a new one in connection with replacing my cambelt and failed waterpump.
Now temps are back to normal again, so obviously the thermostat was the culprit.
If yours hasn't been changed recently (mine was at least 5 years old), I would do it, as it's very cheap and you're 'in there' anyway.
Regards,
Erling
Old 10-01-2012, 06:47 PM
Leon Speed
Leon Speed's Avatar
Originally Posted by Sander_Baas
Hope it’s any use for you, Maybe Leon Speed knows any German (cheaper addresses for you?)
www.autoahrens.de
Not sure if they are cheaper, but they are cheaper than buying directly from Porsche. They know 928s pretty well.
Old 10-03-2012, 04:46 PM
SteveG
SteveG's Avatar
Originally Posted by Bjbpe
I suspect the picture for docmirror is oboma burning the constitution. If that is the case, I aplaud docmirror's inference.
No. He is burning the Tea Party Constitution. Well done, Doc. "And for that we all thank you."
Old 10-05-2012, 08:01 AM
Bart-Jan
Bart-Jan's Avatar
If the pulley is removed from the waterpump, there's a leakage exit hole in the housing of the pump behind it. Normally, you won't be able to see it. It's facing upwards (which I don't understand) and when the waterseal inside the pump fails, the bearings could still be fine for a while, so you won't be able to feel any play. The water will flow via the seal through the hole behind the pulley and will collect inside the pulley, dropping from inside, as can be seen in one of your pictures, I believe. In this case, the bearings will soon be toast. I have made pictures of my pump when I took it apart. You can see it in my post https://rennlist.com/forums/928-foru...rpump-diy.html
Old 10-05-2012, 03:18 PM
Stromius
Stromius's Avatar
Here's a picture or two for OP:
Upside down but note telltale rusted water and also less visible is splash stains behind pulley.
Note side by side (old/new) and new one with weep hole (visible) @ 5 o'clock. Pulley on the left is slightly raised too ie..migrating
Old 10-05-2012, 04:57 PM
ROG100
Basic Sponsor
ROG100's Avatar
Hi Chris,
I just checked and I have not received any emails from you in a few months.
Best regards,
Roger
Quick Reply: What does a failing water pump bearing look like?
