Replacing a seal
Hi Guys
Have taken off the alternator to replace my power steering lines, all good, however on the plastic cover that fits over the alternator there is a felt seal?
I have ordered a new one Sealing ring – 928 603 135 03 but can someone suggest what i can use to stick this back on.
Cheers in advance
John
Cheers in advance
John
The alternator sealing ring that goes between the plastic shroud and the alternator is a neoprene gasket. It comes with adhesive on one side and a peel-off wax paper. Just clean the shroud surface with a rag and solvent, peel off the paper and stick the gasket on.
Chronic Tool Dropper
I figure the foam tape will be cooled by the air going into the alternator... No plans at this point to go back in for inspection anytime soon.
Did this in a hurry while inspecting connections and taking readings, seems to be fine. The original seal was down to the adhesive layer still stuck to the alternator casing, with a little fuzz remaining in a few spots.
