Fahrenheit 451 (long version)
Well, car starts just fine. We let it get up to temp, then she hits the gas. 3K rpm's in loud in the garage, by the way. I adjust the timing and tell her to let off the gas and kill the car. She does, but we smell something bad, burning. Start to see smoke coming up from the hood. She jumps out of the car and out of the garage. I grab the extinguisher from the back seat.
Of course, I go and start sticking my face right where the smoke is coming from, cause I'm smart, right?
Lots of smoke and a horrible smell coming from the back of the engine on the passenger side. Well, I just changed the fuel lines over there. Did I screw one up? I was so careful, but here we are.
Then the wife starts screaming "FIRE!", she could see the glow of the flames reflecting on the garage floor. She instantly runs for the house. I see very small flames through the smoke, shout an expletive, and hit it with one short burst from the chemical fire extinguisher. Flame was instantly out. Still it was a little bit scary. Mostly I was pissed at myself for screwing up the fuel lines.
I went to go see what had become of my wife, she was on the phone with the fire department, of course. She grabbed the kids and and moved them to a safer place in the house, they were asleep. Did I mention this was after 10pm? The garage is not attached, by the way. It has to be 20 feet away from the house, but she has never claimed to be good in an emergency. Anyway, two fire trucks and a police car came. Real nice guys, loved the car.
After they left I had a chance to start wiping up the chemical residue. That stuff is nasty. I barely used any, it still gets everywhere. While I am cleaning, I am also checking the fuel lines, need to know where I went wrong. Can't find my mistake. I used all the right stuff, tightened everything well, no kinks. I finally get my light down deep in back of the engine. There is something down there that looks burnt. Can't really get a good look at it.
Jack up the car and can't f'in believe it. The ashes of a paper towel were resting on the headers. I don't know how it got there, I guess I was wiping something up and dropped it down. Didn't even know. It was probably oily, it smelled so bad there had to be something on it.
So, cleaned up the engine bay, and started the car back up. Ran fine. I probably still need to check out some boost issues, but the car is fine. Much ado about nothing. Really no damage done, even looks fine. I will certainly be more careful with my cleaning rags in the future, however.
It is much more expensive, if you can get it.
I suspect that might be it because the smell was really bad.
depami, I do not anticipate a bill from the fire department. This was not a false alarm, nor did they use any supplies. My firefighter friend explained that these are known as "good intent" calls, and typically are not billed, unless you live outside of certain zoning.
As much as I know I'll hear noises about this, almost all fires in the garage that don't involve large flaming pools of gasoline deserve WATER as the extinguishing agent. Pretty much the ONLY exception is those pools of gasoline, where the spray of water will spread the fuel faster than it can be cooled by the water. Got a fuel hose leaking into exhaust and a resultant fire? Garden hose and massive amounts of water from it. Turn the key off in the car first so the fuel pump stops, very important, but otherwise that big nozzle on the garden hose is the weapon of choice. IMHO.
