Correct ECU for a 1985/86 Porsche 928S
I'm getting a 928 from a local Euro car specialist. It's been sitting for a few years because of a dead ECU (according to the owner of the shop) but is otherwise in great condition. I don't know much about this particular 928 except that it was manufactured in Sep' 85 according to a sticker on the door sill. Does anyone know the correct ECU for this car?
Looking at purchasing an ECU from the following site but there are several for this year and I don't know which one is the correct one.
http://www.ecudoctors.com/porsche-928-1985-1986.html
thanks!
thanks!
Since the 85-86 computers are so robust, a used unit might be a cheaper way to go. They are available from 928 International for less than $400. But I would first verify the computer is the problem and that it's not wiring, grounds, coils or ignition modules.
Matt
Team Owner
^^^ What Matt said,
and even easier it could be a relay so replace the 4 running relays one at a time.
They are # 53 relays Roger sells em for about 8.00 each
Ignition,
EZF,
LH,
and fuel pump
find your fuse relay chart here
www.928gt.com
Look on page 2 under tips and links,
find the fuse relay chart, print it off.
Also swap out the fuel pump fuse and check the back side of the CE panel for power going into each wire of the fuel pump fuse .
NOTE sometimes the fuse holders get corroded and the power wont go past the fuse thus one wire will have power going to it but the other wire wont have any power that would go to the pump
Ignition,
EZF,
LH,
and fuel pump
www.928gt.com
