87s4 reno radio wiring
trying to put back the oem reno, got the special plugs for the back, but my po owner cut wires and here is what i am left with.....
Archive Gatekeeper
Not seeing the back of the radio pic- I have no idea what the connector on the back of a Reno looks like but you might be able to get a connector and/or a pigtail harness made by Stefan at SWStereo.com, he specializes in moderately old German car stereo.
87 s4
i have tried to load these pics but each time says file not uploaded.....having trouble with file uploader on rennlist...bear with me. it loads first photo, then i have problems.
Archive Gatekeeper
No idea whether a Rennlist membership allows for larger pictures, or perhaps you just need to host the pictures remotely, like on Photobucket?
87s4
http://s1065.photobucket.com/albums/u388/nwmgnt/
my main problem is how to connect the rear radio wiring to the car. i have all the rear radio plugs.....
from what i can tell:
--ground
--constant 12v power
--switched 12v power
--antenna?
--then 4 speakers
my problem is with the wiring in the car currently, i dont know what is ground, constant 12v, switched 12v etc....
the previous owner just left all these wires in that radio hole.....
--ground
--antenna?
--then 4 speakers
Archive Gatekeeper
Looks like the same power connection on my '90 GT, and there there must be 4-channels of onboard amplication (?) that use those 2-pin Blaupunkt connectors you got (?) Or are those preamp outs to an external amp to the right of the passenger seat? (Sorry, never seen a stock factory setup in an '87...)
ASSuming the power harness is the same from '87 to '90, here's the pinout, to an adapter Stefan made for me.
