Camshaft removal write-up.
Does anyone have step-by-step instructions for camshaft removal of a 32V engine? Searching the forums turned up lots of good suggestions, but no comprehensive how-to.
Get the engine to TDC. Un-bolt the chain tensioner. Since you do not plan on putting them back on all you need to do is loosen the camshaft bearing caps a little at a time until all the spring pressure is released.
cam timing is the most difficult, but the porken tool will make that pretty easy.
Pirtle had the write up, step by step. it was awesome. pictures and gotchas.\
