Air intake tube design
I recently replaced the rotted tubes on my '81. However, while I was waiting for them to arrive I began experimenting with alternatives. I am thinking of rolling some stainless steel and connecting the pieces with blue high-temp rad hose. (Oooh..Pretty!)
I have 2 questions regarding this:
1) Is the hole on the bottom which connects to the cam gear cover more than a positioning device, or does it provide some sort of cooling function to the timing belt?
2) Is there a specific reason why the tubes reduce at the middle? Is it a flow thing or was it just to make them fit for space/flexibility reasons?
I have guys at my place of work who can make SS tubes for me that I can then cut to length and make fit, I think it will look quite sharp.
What kind of noise? I wouldn't be able to hear a damn thing over the engine while in the car.......
If the people on the sidewalk complain, well....chances are they won't hear it for long anyways!
I redid mine with Mercedes tubes (2 each side with 3" silicone coupler in between. These fit without cutting on a S4: http://reutterwerk.com/forums/showpo...93&postcount=3
In the venturi the air speeds up and then slows down. The sound reflects off the cone.
I went with 3" brake duct. For $50 at Jegs or Summit you get enough for 2 cars.
