Got Brakes?
Supercharged
My first car with enough grunt to think about drilled rotors with vanes. In my uneducated mechanical mind I would have put them on so they were in rotation to force air into the vanes and not "spill" air.
I have new rotors and pads from Roger which will get fitted soon. When I changed the rims I checked which way the vanes ran and whoever did the last set didn't get a matched pair so I have one each way. Must check the part numbers to make sure I get it right this time.
Why "spill" and not forced? The rotors have a coating, do I need to run the old pads or is that just for the cad plated rotors?
Bed your new pads into the new rotors using a proven bed in procedure. Your new rotors won't be plated or painted unless you do it, so just clean the friction faces well with solvent prior to fitting caliper/pads. Recommendation of the use of old pads was only for scrubbing plating off rotors, so new pads aren't ruined.
Rob: Correct.
The rotor is an air pump..in this config..its not.
And on that..with that many holes, its all show..far too much surface area lost to make braking, and mass lost to absorb the energy.
Rotors do not pump air "sideways" and cooling via surface area is 1000s of times slower than cooling via forced airflow internally.
Gary,
The vanes of the rotor are supposed to spill the air not catch the air. I'm not sure if it really makes all that much difference (especially on a street car), and I'm too lazy to look it up, but it has been discussed here several times.
I suppose it is possible that the vanes are properly oriented, but the drill pattern gives the impression that they are installed backward. This is true on some StopTech rotors. On the Zimmerman rotors which most people run on their 928s, the drill pattern follows the vane pattern. These are clearly not Zimmerman rotors, so I guess anything is possible.
flat rotors just seem to have more threashold fade, however, one pump during a threshold brake seems to solve it. with holes and or slots, i think that might not be nessesary.
mk
Mark: Your experiences that holes work..well, thats just working within the limits of the mass of the rotor remaining.
You cant argue against the fact that your temps will be higher, and cooling efficiency reduced in a drilled rotor.
But again, if the rotor you have..is still within the thermal budget of what youre asking of it..yes, it "works"..but its not a working positive.
Over the years I've heard this argued both ways. On a hunch, I went to the Society of Automotive Engineers (SAE) website and found this article. Unfortunately, I cannot read it because I am not a member.
Maybe someone who is an SAE member (Doctor?) can read it and give us a summary.
The Effect of Rotor Crossdrilling on Brake Performance
Date Published: 2006-04-03
Paper Number: 2006-01-0691
DOI: 10.4271/2006-01-0691
Citation:
Antanaitis, D. and Rifici, A., "The Effect of Rotor Crossdrilling on Brake Performance," SAE Technical Paper 2006-01-0691, 2006, doi:10.4271/2006-01-0691.
Author(s):
David Antanaitis - General Motors Corp.
Anthony Rifici - General Motors Corp.
View All
Abstract:
A review of available information on the effect that brake rotor crossdrilling has on brake performance reveals a wide range of claims on the subject, ranging from ‘minimal effect, cosmetic only’ to substantially improving brake cooling and fade resistance. There are also several theories on why brake rotor crossdrilling could improve fade performance, including crossdrill holes providing a path for ‘de-gassing’ of the brake lining material and increasing the mechanical interaction, or ‘grip’ of the lining material on the rotor.
File Size: 1294K
Product Status: In Stock
Included in: SP-2017
See papers presented at SAE 2006 World Congress & Exhibition, April 2006, Detroit, MI, USA, Session: Brake Technology (Part 2 of 3)
Citation:
Author(s):
View All
Abstract:
File Size: 1294K
