Where does this Pin go? Head group
Hi folks
I am doing my Intake and Cam Covers refresh and one of the items that one of the big three recommended (and I bought) was number 38 below.
I can't interpret where they go. There are 5 (five) of this and P/N is 928 105 262 00 - Pin
Does anyone know and can help me understand? Any picture?
Many thanks
Many thanks
Team Owner
is the pin you bought a stepped pin?
if so then its used for the oil block off on the unused cam journals,
it is placed into the oil feed hole and the cap for the cam holds it in place,
this keeps the oil from falling when the engine warms up
link with pictures of the pin see post 24 for a pin picture
https://rennlist.com/forums/928-foru...w+oil+pressure
Mr Merlin,
That is the Pin I am talking about. Darn it! I just assembled the Driver's side Cam Cover without touching that. But I cannot recall seeing anything out of position, but only God knows now.
Would you recommend removing the Cam Cover and have it replaced or would you take a shot and check the oil pressure once the whole work is completed? I am hoping that if I get good oil pressure I will be able to leave it, but if not, it will be pretty hard to get back there. The whole area seems to be "virgin" since left the factory and lots of miles (about 150k).
You won't have enough oil pressure in the heads to oil the cams and lifters, ya gotta go back in. Sorry.
Team Owner
what Sean said^^^^^^
I dont know whats the condition of that car as it was customers,
it was running fine when it left,
i did put in the 5 pins
Sorry, hit the send before I typed it all.
So will the cap and pin that were there be displaced when I r&r the cover and its gasket; or is it one of those things that is highly advisable but not mandatory? Or is it an upgrade?
Sorry for questioning, just trying to understand.
Former Sponsor
Wow, thanks to you all.
If these are anywhere close to all deteriorated rubber and plastic that I touched during the refresh, I certainly have to get back there.
Once I get back home, I will do it and keep everyone informed. If something weird is found, I will post some pix for the tank entertainment.
