if the torque converter is turning with the engine then you have internal transmission damage,
and you will be dropping the trans to investigate further, maybe the front pump splines have sheared off these are turned via the torque converter
This was what happened to me. Fixed with a new mercedes branded front pump for ~$300.
I'm sure I did, have not looked at anything computer wise except this Eye-pad this weekend. The couch has been comfortable.
Will look tomorrow morning for sure. Did he contact you here?
