928 Forum 1978-1995
Sponsored by: 928 Specialists
No fuel out of pump
Old 07-25-2012, 05:34 PM
tailpipe
tailpipe's Avatar
The word on the street is MEK for solvent with the ultrasonic I also have one but have not tried it yet let me know how it goes pls?
Old 07-25-2012, 09:44 PM
jpitman2
jpitman2's Avatar
Isnt MEK VERY nasty stuff, as in carcinogenic?
jp
Old 07-25-2012, 09:50 PM
SQLGuy
SQLGuy's Avatar
MEK IS nasty stuff. Don't know about its carcinogenic properties, but any drop of it that touches your skin will go right through the surface and kill that spot. Be very careful working with it.
Old 07-25-2012, 10:18 PM
Dave928S
Dave928S's Avatar
MEK (Methyl Ethyl Ketone) is the specific solvent for ABS plastic, is present in the glue for that material, and is used neat as a cleaner prior to gluing ABS. It is also the solvent (with a red dye in it) commonly used by plumbers when cleaning PVC pipe prior to gluing, and is sold in cans by the pallet load from plumbing supplies for that purpose. I've used it for decades using normal safety gear for all sorts of plastic fabrication.
Vapours are obviously to be avoided, as is skin exposure, and it is highly flammable.
SQL Guy .... with respect ... you must be thinking of some other substance ... it doesn't "go right through the surface and kill that spot".
The pump has plastic terminal components, and so I wouldn't immerse it in MEK as those plastic parts will get damaged.
Quick Reply: No fuel out of pump
