a few good laps at Thunderhill...
My "No-shift O' matic" 1979 racer did pretty good on Friday.....I managed to break my personal best lap time over 8 times.....pretty good considering I had a great gear selection of 4th 4th or 4th....
Here is 3 laps under my previous personal best......conditions were good but hot, around 90F.....calm wind...
Not the sharpest tool in the shed
torque advantage is EVERYTHING..... :>) Might as well put my brute 257 ftlbs to work....bummer its at 4250 vs say 3000 which would be nice given my current "no shift-o-matic" dilemma........I could probably drop another second with that extra torque...
cool video!
great job!!
great hands too by the way. more control and feel now , huh???? it shows
nice!
with 2 more gears, that might give you 2 seconds at least!!!!
nice!
Given my newly discovered busted sway bar-LSD issues I am going to pull the front shocks and have them tested-rebuilt....clearly I need more control in the front end for high G corners....
Your running the slicks so you are in good shape. i dont know how much the aero helps at these speeds, but i ran my black car to a 2:01 with no aero, and old crummy toyos. with the slicks and aero down to 1:59.0. im thinking the tires were most of it. certainly for me, another second or two or so for real slicks too.
whats the HP again, arent you in the 250rwhp range? i seemed to remember 2:04 being a prettty good time for that kind of hp and 2:01s with the 320rwhp , all on "ok" DOT slicks . (hoosiers of the day, being about 1 second faster than the toyos)
Right now I'm at 2719lbs (no driver) and 243whp.....not exactly powerful....so 2:04's (with a working trans) is pretty good.....same as Scott's best at the same weight and an extra 50whp....
I am SURE I can get another 100lbs out of the car easy....maybe as much as 120lbs...
The slicks do count for a lot......but I did run 2:06.5 on slicks in the Estate at only 215whp....
